Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23425
We are wondering what the ideal temp. range should be in the room where the freezer is.
    Problem Solver:
  • 20 Answers
The cooler the better, most freezers use the side walls of the unit to disipate heat generated. The unit will use less energy in a cooler enviroment. The trade off is added heat to an area that is air conditioned. Overall you will be better off inside if it is hot outside.
Posted on Aug 07, 2010
What temperature should my frigidaire model no. Fkfh21f7hwb upright freezer be set at?
Temps down to about ) are ideal for long term storage. Warmer temps will lessen the time you can store stuff in freezer for best food quality preservation.
Aug 04, 2017 | Frigidaire Freezers
Hi.. I have a defy upright freezer.. it is currently displaying an error "c2 !". Defy say this is because of the change in outside temp. Is this true, how long is it supposed to last? Many thanks.
If unit is not in a controlled environment yes temp will be confused and will take 24 hour to correct but if outside temp is changed it will do again and again all units designed for controlled temp room not outside in garage or out buildings with no heat or cooling controled room
Feb 28, 2017 | Freezers
I have a freezer bosch log/xx model dc125e12raw5r600 tempretureis only -5 is this normal
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The ideal temperature range for a freezer is -2/+2 degrees F. This temperature range can very depending how full the freezer is. If your freezer is jam packed -5 degrees is good. If it is half full, +2 degrees F. is a good setting.
Too high of a setting such as -20 degree F. will cause freezer burn (bone dry your food).
Your compressor will kick in and cycle until it reaches the temperature setting. You can save on your electrical bills based on your evaluation of the necessary temperature setting.
Oct 19, 2014 | Bosch Freezers
What is ideal freezer temp setting ?
dear sir /madam
the ideal freezer temperature is 0 fahrenheit(-18 celsius) for storing food. and - 10 fahrenheit (-23 celsius) is recommend when freezing food.
and generally 3 to 5 celsius (37 to 41 fahrenheit) is ideal for refrigerator
hope answer the question
thank you
please vote!
Aug 17, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
How to set temp in the freezer box
dear sir/madam
please find out temperature control switch on control panel then make it on ideal setting. for freezer 0 Fahrenheit (-18 celsius) for storing food and -10 fahrenheit (-23 celsius) is recommend when freezing food. please set on ideal setting.
thank you
please vote!
Aug 13, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
Freezer is hot on the sides is this normal?
Good day,
Yes, that is normal. It is ideal to not be in a hot room but as it reaches temperature and begins to cycle off and on it will become somewhat cooler.
Jul 20, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
WHAT IS THE CAPACITY OF MODEL F-450BAE FLAKER
It is to produce 450 pounds of ice in 24 hours under ideal conditions. Manual says anywhere from 345 to 440 depending on factors of water temp., ambient temp., and system pressures.
Hope this is what you are looking for.
Mar 03, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Bar Chest Freezer Large
I would think that the reason the red power wire melted, was because of high amperage, not getting wet. After you replaced it the condenser fan came on, but did the compressor? It may have went out before and that's what caused the bad wire. If you have a volt/ohm meter I can help you check it out.
Jan 29, 2008 | Summit Commercial 7.50 cu. ft. / 212 liter...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23425 Logo
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
