Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I have a 20 hp 42 in cutting deck mower. When I let out on the clutch, the engine shuts off. I am sure it is a safety switch, but I cant locate it.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
The safety switch is under the seat. It senses weight in the seat, and if it's not working properly, the engine will die when you let out the clutch. It's not always a bad switch - it could have simple come loose or the mounting may be broken or misadjusted. Or the connector to it could be loose, or the wire could have been pinched and broken, so check it all out before you replace the switch.
Posted on Aug 07, 2010
WHEN I LET OFF THE CLUTCH THE MOTOR CUTS OFF
You have a bad safety interlock switch someplace. If you're not on the seat and you let off the clutch, it will die, so it's possible the seat safety switch, or operator presence control as it's commonly referred to, has worn out and needs replacement.
Jul 22, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Where is the part located that shuts the mower off when you release the clutch
There is a safety switch for the brake clutch and if the seat safety switch is not activated by someone sitting on it, then the mower will die. So if you are sitting in the seat and the brake clutch is released and the seat safety is faulty then the engine dies, so the seat safety is where you should start looking.
Aug 31, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
20 hp 42" deck will not turn over. Will start if I
there is 2 to 3 safety switches on there and any one of them will stop it from running. there is one in the seat, one on the engagement of the mower deck and one in the clutch pedal. some models also had an in-line fuse.
Jul 14, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Cuts off when i relase the clutch ,also the pto will not engage
Check your clutch safety switch, might be faulty or need adjustment.
Apr 07, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 15.5 HP, 42" deck. Engine shuts down when brake/clutch is released.
Check that the seat switch is functioning, pull the seat up and put a paperclip in the switch and try it that way if it works then you need to replace the safety seat switch.
Jun 12, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Mower won't run
Did you try jumping the switch under the seat? Why would the foot switch shut it down? If it is the switch near the foot and you can't replace, then jump it. But be careful this will disable saftey features. Hope this helps.
May 25, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Tractor starts fine but wheni take my footh off the clutch the tractor dies
Most of the time its the seat safety switch .
Alway engage and disengage mower deck too as there is a safety switch there too, some times its just needs moved some, its not the clutch pedal safety switch.
Feb 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
419 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
