Question about Hitachi HTS541612J9SA00 120 GB SATA Hard Drive
I want a converter for Hitachi HTS541612J9SA00 120 GB SATA Hard Drive to usb do you know wich one I need..?
  • Hitachi Master
  • 13,433 Answers
You need a 2.5" inch SATA to USB external harddrive enclosure.
since its a laptop hard drive you need a small case.
for example this one http://www.amazon.com/2-5-SATA-HDD-Enclosure-Black/dp/B0018TCB0O
Posted on Aug 07, 2010
Drive address setting with Hitachi (39T2703) 60 GB SATA Hard Drive
i'd go to the hitachi website and download the driver to your pc,then install/update,look on ystem administrator specs for info about hard drive,simple
Jun 10, 2012 | Hitachi (39T2703) 60 GB SATA Hard Drive
I have a Hitachi internal hard drive that i would like to use as an external hard drive to boot from my e-sata port, i have a Toshiba portege and i curently use two hard drives to boot from, one for work...
yes you need power to the external hard drive whether ide or sata possibly depending on your hard drives power supply
12V+5V AC sata Adapter Power Supply HDD HARD DISK DRIVE
hope it helps
Mar 27, 2012 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Please how do I access my Hard drive it fell while in operation
It all depends on what is damaged. The best thing to do is open the casing and remove the hard drive. Depending on the type of drive it will usually be a SATA or a PATA drive (on rare occassions laptop drives are used). If you are using a laptop then you will need to obtain a USB converter to allow connection. If you are using a desktop then there should be unused connectors inside on the motherboard. PATA drives require a 40-way ribbon calbe, SATA drives require a much smaller connector with 7 pins and an 'L' shaped groove. It is probably easier to obtain a USB to PATA or USB to SATA converter if you do not have the right cables or are unfamiliar with computer hardware.
Once you get the USB to SATA/PATA converter, connect the hard drive to the laptop or desktop and see if the computer recognises it.
Feb 16, 2011 | Western Digital External USB 2.0 80 GB...
Was sent my old internal harddrive after a warranty service to make a backup from and i want to know what connection i need to make it usb. 5K250-250
you can purchase a huge range of drive interfaces from your local computer store. Make sure you get an interface, or USB external case to suit the drive interface ( PATA or SATA ) plug the ting in and connect to your pc through a usb port... then I would copy the entire drive contents onto another drive..
Nov 02, 2009 | Hitachi Travelstar 5K250 HTS542525K9A300...
Sata HDD very slow
Dear friend you need a sata board to get maximum speed of sata driver connect it directly to motherboard sata jack converter does not give full sata speed
Jul 22, 2009 | Hitachi Deskstar T7K250 250 GB Hard Drive
HELP! retrieving files from corrupted drive
he should keep the hard drive in the freezer for one day
Apr 24, 2009 | Hitachi Hard Disk Travelstar E5k160 120gb...
How can i make my seagate hard disk an usb hard
It is quite easy, do not worry.
You only need to bought and USB enclosure, here is a link to many products on ebay
http://search.ebay.com/search/search.dll?from=R40&_trksid=p0.m37.l1313&satitle=hard+drive+enclosure+usb&category0=
then you have to connect your hard drive inside the enclosure and the enclosure to your computer using the usb cable and that's it.
Just be carefull about the enclosure, I guess it is a Hard drive from a desktop, is in it? because some enclosure are for laptop's hard drive.
Also you need to know if your hard drive is SATA or IDE, IDE is the normal gray bus cable with fourty some pins, and the SATA it is a really small cable (I do not use technicims to not confuse you even more).
Also, there are some adapters from IDE/SATA to USB that you can buy in your local computer store (do not go to bestbuy, compusa, ... they only sell external hd), or also get it from ebay.
The only diference between the enclosure and the adapter is that the enclosure looks better :D, and the adapter is just a bunch of cables.
Mar 19, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Hitachi 500 GB sata Hard Drive
i have just format my compter now im haveing problums geting my sata hard drive back in i have the floppy disc what came whith it not shore how to install it
Jun 13, 2008 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Hello
i want to register a complaint for hard disk drive
Model No. : HDS721616PLA380
cAPACITY ; 160 GB
ADDRESS ; 104, 1/50, GANGA APPARTMENT, LALITA PARK, LAXMI NAGAR, DELHI-110092.
PH. 9899970450, 9868270450, 99999073373
ASRAR ALAM AZAD (PROPRIETOR)
SAURAV CHATTERJEE (EXECUTIVE)
May 28, 2008 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Hitachi HTS541612J9SA00 120 GB SATA Hard Drive Logo
337 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
