Question about M-Audio Fast Track USB (FASTTRACK) Audio Input
I plug my guitar cord into the M-Audio FastTrack and im not getting any signal into protools at all. It's not picking up the guitar sound at all.
    Champion:
  • 219 Answers
Make sure you inputs and outputs are configured correctly in protools
Posted on Aug 07, 2010
  • dorothy_mcmi
    dorothy_mcmi Feb 23, 2012
    I'm having the same problem.. just got it and want to return it..
    I have my guitar plugged into the m-audio box and that plugged into my laptop ..I turn pro tools on and I see no signal and hear nothing
    even when I turn the metronome on I can see in the master the volume going up and down but I can't hear the tick
    I don't know what you mean by input and output configure correctly in protools ..can you help me?
What i/o do i need to hear my tracks through protools
It depends on what version of Protools you are using. And also on what it is running on, PC or MAC. Starting with v9 Protools is hardware independent. Which means and audio interface (I/O) should work just fine for listenning to tracks from protools. Depending on your computer it will support direct audio or core audio. make sure the interface supports ASIO as that is the standard and default way to go
Dec 26, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
I can record voice, but no guitar. Just as many people on this forum, but i didn't saw a proper answer for my problem. I can hear my guitar im using pro tools SE. The light on my fast track lights up,...
In Protools go into hardware setup and make sure that your interface is being read properly. It may be set to something other then your fast track. Then, in the MIX window make sure that your input is set correctly. If your microphone is plugged into input 1, your input on your protools track should correspond to that.
Sep 06, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
I can record voice, but not guitar. I see the signal for the guitar, but just not recording. I following the same directions I would for voice but does not work. Any suggestions? Thanks
There is a button on the front that switches between XLR and 1/4" inputs. Make sure that your mic doesn't require phantom power, as the FastTrack doesn't supply the right voltage.
Mar 14, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
I get a high pitched noise when in pro tools
I don't know what devices are connected to your audio input ports, sounds like gain is too high on a microphone or guitar or speaker setting too close to your work station, sound like feedback loop.
Nov 02, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
No sound recognized in Audacity from Fast Track M-Audio
First thing is what operating system is on the computer.
Second is what does device manager say about the recording interface?
Third in audio properties from the task bar icon, what is the default device for recording?
Feb 23, 2018 | M-Audio Fast Track USB (FASTTRACK) Audio...
Sound in one ear only
The Fastrack only has one audio input signal to the PC. You'll need to set your recording software to mono, then you can add stereo fx in your audio software.
Jun 06, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Low record level for guitar
first of all you want to have your guitar amp at a decent volume but too loud, just enough to be able to get a good signal. when you have done this turn up the gain on your mic channel so that your VU meter (level meter) on the recording software shows a reading of about half way up the meter. If you can not achieve this with the soundcard alone increase the gain on your channel in the software.
This sound guarantee a good signal but as with most recordings you will still have to boost the signal without it peaking. to do this use a compressor or a limiter and turn the gain up. if you use these dynamic effects correctly you will achieve the guitar level you want.
Jan 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
M-Audio Fast Track USB (FASTTRACK) Audio Input Logo
336 people viewed this question
Top M-Audio Televison & Video Experts
Paul Bade
Are you a M-Audio Televison and Video Expert? Answer questions, earn points and help others
