Question about Garmin zumo 550 GPS Receiver
My Zumo has gone completely dead. I plugged it into the power source and nothing. Didn't do anything different than any other time I've used it.
The car charger was going bad (as I learned) for my Garmin Zumo 550, so while using, I began to see a message similar to "this USB power source has been connected to the wrong device"...or something like that. The charger eventually quit working all together, and I noticed the black and red wires were exposed at the connector part that goes in to the Zumo.
I purchased two car chargers on eBay that were compatible with the Zumo (didn't buy actual Garmin brand) and neither one works; it doesn't power up the Zumo immediately like it used to do. Is it really necessary to buy a Garmin brand charger--I wouldn't think so!
Any ideas on how to get the new car charger to work? I have tried the reset at least four times!
I AM able to charge it using the AC adapter in that bottom port, but of course, there is no audio and the charge doesn't last very long.
Help!!
Thanks! Nona at nonaking@hotmail.com
Posted on Sep 13, 2010
My zumo has gone completely dead
Posted on Aug 14, 2010
I have a Dell Precision M60 laptop and the charger adapter's led light is on when i plug it in, but the laptop won't turn on.I've replaced the battery and tried a different charger but that...
Unfortunately it sounds like you have an issue with your motherboard. If you remove the battery and just try to power on the laptop using the AC adapter and it still won't power on then it's probably the motherboard. The power supply circuit (where the AC adapter plugs into) for the motherboard is integrated into the motherboard.
Sorry. If it's still under warranty Dell will replace the motherboard.
Sep 10, 2011 | Dell Precision M60 Notebook
HI I have Zumo 550 when I first switch it it comes up with can't maps press OK you press OK then starts to work but starts at 1am on the clock and in night time mode after awhile it goes to the right time...
If your zumo 400 or 500 series will not power on, or performs strangely after powering up, follow the steps (described on the Garmin website) below to perform a soft reset:
  1. Connect the zumo to a power source such as a computer or AC outlet
  2. Hold the zoom (+) and ON buttons at the same time for five seconds
  3. If this does not restore power, remove the battery for five seconds
  4. Place the battery back in the zumo
The zumo will now power on. Because the battery may deplete while the zumo is locked up, it is ideal to leave the zumo connected to power to allow it time to charge.
Once the battery has charged, follow the steps on the Garmin site to update the operating software in the zumo. (just copy this link to get there https://buy.garmin.com/support/searchSupport/case.faces?caseId={8576ba20-e948-11dc-d6fc-000000000000} )
Good luck,
Michael
Feb 01, 2011 | Garmin zumo 550 GPS Receiver
Hello my name is Amy & I have a 50 inch toshiba dlp (56hm66). I have no lights on or power. It's completely dead!!! I read the manual & followed everything about the lamp, how to restart, made...
Tv have no power at all?U already check the source?Yes,most likely the tv DM power supply board is dead or could be anythings on the highvoltage deflection circuitries on the tv.Check the DM power supply board like for dying or dead capacitors and circuit fuse breaker.Have no skills to do this call and get an estamate by tv Tech. to get it fix.
Jan 13, 2011 | Toshiba 50HM66 52" Television
Hi, I have a Zumo 550 which I bought used and known faulty (I got it cheap). The problem is that it does not power up either on battery or external power. Is the unit completely dead or can it be...
Try the car charger as well. Be sure the charger you are using is in fact working and making proper contact. metimes the uit takes awhile to respond if the battery is flat. Remove the batery and re-insert before trying again.
Jan 19, 2010 | Garmin zumo 550 GPS Receiver
Lenovo R61 Dead
The power supply in most computers has a fuse, either internal or external, that can blow without you noticing. Basically, you've been on battery operation this whole time, and the battery's finally gone dead.
It will be necessary to open the case and examine the power supply section. It may be possible to replace the fuse yourself, but any operation of this nature that involves opening the case will void any warranty you may have.
Sep 06, 2009 | Lenovo R61 T7300 Notebook
Garmin zumo switch on problem
Use the allen wrench to remove the battery. Let stand for 5 minutes and replace the battery. It should start fine. Mine has done this 3 times since I purchased it.
Jan 05, 2009 | Garmin zumo 550 GPS Receiver
My garmin zumo will not turn on.
Have you also held the power on button for a couple of minutes, with the battery installed, and without the battery installed. There is an issue with the garmin dying, some cases a new battery helps, other cases, just leave the battery to charge for several hours, worst case is that you have to ship it to Garmin. I had a couple of Dead Zumo, however, removing the battery for several minutes, putting it back and clipping the zumo in the car holder did the trick for me. I also have a spare battery and allen wrench, just in case...
May 26, 2008 | Garmin zumo 550 GPS Receiver
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
446 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
