Question about DeLonghi EW0507 Oil Filled Radiator Heater
Why does the coird get hot? Thanks - DeLonghi EW0507 Oil Filled Radiator Heater
  • DeLonghi Master
  • 43,501 Answers
The cord gets hot because of the load on the unit... thses heaters pull alot of electric and the electricity going through the cord makes heat... make sure that you have it plugged directly into the outlet and do not use and extension cord... that will make it worse...
some heating of the cord is very normal...
heatman101
Posted on Aug 07, 2010
Testimonial: "Thanks so much! Your solution was very helpful!"
How to remove paraffin? Thanks.
hot water, hot air drier, anything that is hot enough to melt the parafin
dab with clean cloth when hot
Nov 11, 2017 | Health & Beauty
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Suzuki gsxr 4oo ignition wiring,,,with help from guy here,many thanks,have removed ign barrel,only two wires go to this,one earth,one live,with no more wires to key.is this okay,i thought for feed in you...
The switch would not normally have earth connection. Purpose of the switch is to control power to the motorcycle. You should find one wire HOT and one NOT HOT (wire) when in the off position. Connect your accessories to the NOT HOT when off wire. The NOT HOT should become HOT with the switch in the ON position.
Did I answer your other question here today (Sunday 12-20)?
Thanks for your question at FixYa.com
Please vote - we need votes here
thanks
Dec 20, 2009 | 1995 Suzuki GSX-R 600
Cold is hot, hot is cold.
Switch the hoses on the inlets and see if it corrects it. If it still is out of wack then somthing may have shorted or broke on the temerature selector switch. But I would switch the inlets before doing anything
Nov 09, 2009 | Saws
We have gravity water feed and is not filling up quick enough. Could i mix with hot water as well.So putting in a y to mix cold and hot together. Thanks Dave Williams
hi dave. actually you are supposed to fill a dishwasher with hot water only.
the long term fix for your gravity feed water system would be a shallow well pump.
please rate my answer as a fixya ,thanks
Feb 18, 2009 | Hoover HD95M Free-standing Dishwasher
Hot water will not fill into the tank when starting cycle.
The ECU is at fault.
Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Hot water for dishwasher
Hi thanks for the question. before you start your dishwasher turn on the hot water tap at sinc let the water get hot . then start the dishwasher it will be hot enough for the rest of the cycle. thanks the appliance doc
Oct 06, 2008 | Dishwashers
Space between doors on cabnet is very hot to touch ref seems to work ok
hi. thanks for the question .the heat between the doors is normal . its hot to keep condensation from running down the doors .but pull fridge away from wall. remove back panel and clean all the coils. very important. thanks the appliance doc
Sep 30, 2008 | Maytag 23 cu. ft. Side-by-Side...
No hot water reaching the tub
hi thanks for the question if you cleaned the screen and no hot water i would replace the water valve thanks the appliance doc
Sep 27, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Hot water cycle flow problem
hi thanks for the question their is a screen in the water valve to catch any dirt you can try and remove the screen in the water valve and try again if it works ok . it usually works thanks the appliance doc
Sep 24, 2008 | Washing Machines
Open Questions:
See all DeLonghi EW0507 Oil Filled Radiator Heater Questions
DeLonghi EW0507 Oil Filled Radiator Heater Logo
237 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
