Whats wrong with my projector?
Hi, i turned my projector on as normal today and usually when i press the power to my sky box on the image comes on straight away. now however i just get the blue screen with a no input message. then the projector power ight goes to red even though its still on. at this point no remote control functions work, and the only thing i can do is turn it off at source. could the bulb need replacing? im not sure as it still projects the blue screen. any ideas?
  • trezza May 02, 2008
    i had a spare bulb so i thought i may as well try it. it turned out it was the problem after all, however it gave very confusing symptoms for a mere bulb failure! thanks marie for your suggestion, but im glad i didnt start messing around with it too much!!
  • 563 Answers
Hi Trezza
No this is absolutely NOT a lamp issue.
Take of the top cover and switch on the machine - check that all the fans are working.
If they are all running , this might be a faulty Mainboard.
If you can't spot anything wrong yourself , rather take it to a repairer for a proper inspection.
Good luck and thanks for using Fixya !
Posted on Apr 29, 2008
  • Marnus Jacobs
    Marnus Jacobs May 06, 2008
    Hi Trezza
    Yes the sympoms you gave does not match that of a faulty lamp at all , but I'm glad you resolved the problem yourself without having to spend a load of money on repairs.
CTX EzPro 550 data projector and laptop operating on Windows XP
Usually the key combination is 'Fn' (function Key) + F4 (or which ever F key that displays the symbol of monitor on it). This key combination is used to toggle the display between monitors.
Please come back and vote for me if this turns to be helpful for you. Thnx
Mar 20, 2010 | Electronics - Others
How do I make the picture fill the width of the screen. I see a 16/9 and 4/3 buttons but they only make the picture taller, I need to make it wider. I have a Vidikron Kronos One projector.
Could you please give me more detail as to what you mean by make it wider. Is the picture currently using the width of the projected image? Have you used this projector before? Once I have more information I can assist you further.
Thank you,
Lee
Feb 08, 2010 | Televison & Video
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
When setting my dish for sky i have a great quality and signal but the ID number coming up on my sky box is 13e instead of 002
Hello John,
http://www.dishpointer.com/ is a good web site just incase your hitting the wrong satellite your wanting to line this upto 28.2e Astra.
If after doing this the ID does not work then it may be worth forcing a download onto the sky box.
If you not familiar in how to do this, then follow these steps. turn the power off to the sky box or unplug from the back of the box itself. Then what i want you to do is hold down the Backup button on the front of the box. then reinsert the power or turn back on. while you have the backup button pressed in.
Hold this button down until all the lights on the front of the box illuminate. You should now see on the the screen a warning message come up informing you not to disconnect the power or the sky cable.
This takes approx 10 minutes to do this. It takes longer if you watching this so make yourself a Cuppa.
Hope this helps you out.
Little Dish Fitter
Oct 02, 2009 | Televison & Video
How to connect projector to sky plus box using RGB
hi i have the same projector (acer x1160) and want to connect sky to it also i was going to go with scart to vga but if you say that donsn work then i might try to connect the 10 pin vga that is on the back of the sky box to the 15 pin vga on the projector i will let you know if it works.
Nov 04, 2008 | Office Equipment & Supplies
Thomson digital receiver
hi i think you might have the wrong software on the box,turn you tv on and put it on the sky channel take your viewing card out of the stb turn the box off then take the power lead out, wait till the stb powers down then put your finger on the backup button keeping it pressed put the power lead back in and holding the backup button wait till the on screen message comes on your tv, wait till the tv screen goes blank then put your card back in turn your box back on and try to record 2 channels at the same time this should solve the problem. if not it will be the cable or the quad lnb.
Jul 22, 2008 | Audio Players & Recorders
Screen size problem!!
Hi there
Now the image can only be made that big or small. You will have to move the Projector closer to the screen.
Apr 05, 2008 | Sanyo PLC-SW30 Multimedia Projector
Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Jan 19, 2008 | Televison & Video
Connecting Sky TV to my projector
Which sky box do you have and which model projector. are you trying to use SCART or YUV or what.
Please describe the connector available on the sky box and the projector. if you dont know or they are not labeled nicely please refer to the chart in the link below and let me know what is on both boxes. I will do my best to reply with EXACTLY what cable you need and a good place to order it, US and UK.
Also let me know what distance you need to run.
http://h71028.www7.hp.com/hho/downloads/HP_connector_chart.pdf
Oct 10, 2007 | Office Equipment & Supplies
Projector does not turn ON
try removing the lamp, usually quite easy, you need to find the door for the lamp. lamps are customer replaceable, usually. If the lamp is bad you can usually see it damaged in the lamp. kind of like you might be able to see the broken filament in your normale house hold light bulb. good luck.
Dec 24, 2006 | Canon LV 7345 Multimedia Projector
445 people viewed this question
jasbo
jasbo
