Question about Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens
Gave a close look clean on my 55-200mm today. Received new Jul 14, 2010. Approx 1/4" from center, there is a small like 1/4" smear line. This is on the inside looking at front of lens. Line appearance is not on outside. How do I get rid of this "whatever" line? Also, as to whom I should contact? Doug Jorgensen
  • 571 Answers
It is usually not a good idea try to take apart a new camera lens by yourself - unless you're a professional. Better to take it to the dealership repair store and see if it really inside and if the lens has a warranty, try to get it replaced by the seller.
Posted on Aug 07, 2010
I need a new SHENG BANG HD-1688 AA VOLT BATTERY MOVEMENT
Check on Amazon or Madeinchina .com, Tradetang may be a good place too
Nov 11, 2014 | Watches
New 60" lg TV has a crisp white smear with pinstriped lines
Bring it back. You have done nothing wrong and the dealer may have a Bad Batch of units.
Mar 22, 2014 | Computers & Internet
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannon Pixma MP830 - smearing on front when printing
If you have taken it apart that far then you are way ahead of the game. My suggestion would be to clean the head or anything the ink touches in a vinegar/water solution. The vinegar dissolves any dried ink whereas the soap may actually gum things up. If that doesn't work or improve things I would say that your print head has a seal problem. The replacement print heads are worth more than a new printer so you can probably figure out whats cheaper to do.
Aug 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Unstable internet connection with a DSL2640U
I've heard that the issue can be resolved with a firmware update.
Go here to get it.
http://www.dlink.co.za/dsl-2640u_t.php
Jul 20, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Black lines on received faxes
look for a corona wire, close to the drum
  1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
  2. Return the tab and snap it into the home position.
zl42b.gif Note
    If the tab is not at the home position, printed pages may have vertical stripes.
    Jul 18, 2008 | Brother IntelliFAX 4100 Laser Fax
    Getting lines in photos
    go to the canon web site they have an advisory out on this I just got mine back actually they kept my S1 IS and sent me a new S5 IS because "they did not have the part and wanted to expedite my repair"
    Here is another site I found when I encountered my problem
    http://www.imaging-resource.com/NEWS/1164376280.html
    I sent my camera in per Canons instructions, received an e-mail a few days later(1/9/08) confirming that they would repair it a few more days later (1/16/08)I received another e-mail confirming that it had been repaired and shipped. Today (1/17/08) I got it and to my very pleasant surprise the box contained a new S5 IS!!! I will be sending them a very nice THANK YOU for it after I post this.
    PS: e-mail accepting repair 1/9/08
    1/16/08 e-mail stating it shipped on 1/15/08,
    received 1/17/08 via FED EX
    Jan 10, 2008 | Canon PowerShot S2 IS Digital Camera
    Black Smear
    go to page13-9 routine maintenance section, where it says to clean the glass strip on top of it there is a white plate (shown) does that plate have ANY dirt or spots etc......?
    It MUST be completely WHITE or it will give you black streaks. if it cannot be cleaned then use white out to cover. ( makesure it is completely dry before using).
    Oct 08, 2007 | Brother IntelliFAX 885MC Plain Paper...
    How to disassemble a pantech c300
    I used a micro screw driver set that can be purchased at Home Depot. There are two hidden screws: one on the top piece where the display is and one on the bottom piece where the keyboard is. The hidden screw on the top piece is under a silver rubber circle at center bottom of piece. The hidden screw on the bottom piece is under a silver rubber water drop shape located by the antena. These rubber covers can be removed by wedging them out with a mirco flat screw driver or pin.
    Good luck...
    Jul 10, 2007 | Pantech C300 Cellular Phone
    Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens Logo
    59 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
