We have a Dimplex Exbury EBY 15 electric fire. The fire has had a mental breakdown. While doing a demonstarion to a fried I pressed the remote control too many times. It started to overheat even the casing becoming red hot and was in danger of igniting. My question is can it be reprogrammed? Your advice would be much appreciated.
  • 4736 Answers
SOURCE: replacing bulb in dimplex electric
To replace the bulbs, your will need to remove the plexiglass front, then remove the logs and set them off to side where they won't get stepped on. Then lift up the plastic simulated ember bed. You now have access to the light bulbs. The required bulbs are 60 watt small base chandelier bulbs.
Hope this helped you, Margo. Thanks for choosing FixYa.
Posted on Aug 18, 2011
SOURCE: Electric Heater Coils Always On
We use the STW0925H! in 60 rooms on this property and have encountered similar problems that were caused by weldedd contacts on one of two relays that controls the electric strip heat. They can be replaced if needed.
PTHP's and PTACs employ thermal fuses as well as a bimetal limit stat on the heating element to limit risk if fan motor were to fail and the heating element were to remain energized. It would be wise to check that both are fuctioning properly while you are servicing the unit.
Posted on Mar 07, 2008
  • 4736 Answers
SOURCE: my dimplex has a remote
You definitely have an electrical problem either with the remote box or the the A/C unit itself. Something within either of the aforementioned is overheating and use of the air conditioner should be stopped immediately, as it is a fire risk. Unplug everything from the wall outlet and contact a service company that services Dimplex Air Conditioners. This is not a DIY fix!
Posted on Feb 07, 2011
  • 4736 Answers
SOURCE: how do i change the
TO REPLACE LIGHT BULBS
1. Open the steel curtains (remove glass doors if applicable).
2. Remove the log grate retaining screws and remove the log grate.
3. Pull the rear edge of the log set forward by grasping the ember bed by the sides
(handle the log set only by the ember bed and not the logs) and pulling firmly
until the rear tab pops out from under the back ledge, then lift out.
4. Examine to determine which bulbs require replacement.
5. Unscrew bulb counter clockwise.
6. Insert new bulb screwing clockwise.
7. Replace the log set by inserting the front edge, pushing the back down until the
rear tab snaps under the back ledge and the logs are resting against the mirror.
Quantity 4 clear chandelier or candelabra bulbs with an E-12 (small) socket
base, 60 watt rating. Example GE 60BC or Philips 60CTC
CAUTION DO NOT EXCEED 60 WATTS PER BULB
Posted on Feb 24, 2011
  • 4736 Answers
SOURCE: Cant get my dimplex club
Do the rest of the functions of the fireplace work? If so, turn the Master On/Off Switch to OFF and plug the unit for 12 to 15 minutes. After the time has elapsed, plug the unit back it and turn the Master On/Off Switch to ON. Then turn on the flame function switch. Hopefully, that timeout allowed the unit to reset itself and the flame function is now working. If it isn't, either the flame function switch is faulty or the circuity to the light bulbs and the ro-tater motor that turns the shaft, that he bulbs are attached to, has failed. Without knowing how old the unit is and how much use it's had, it's hard to pin down one thing that is causing the problem. If it's any consolation, you are not alone. Hundreds of these electric fireplaces (all makes & models) fail every year.
If all else fails, contact Dimplex USA, Technical Service at 888-346-7539.
Hope this helped to solve your problem.
Posted on Mar 17, 2011
Fire wont mist ad keeps turning its self off 3rd time lucky at posting this as not a car or truck and it keeps coming up under cars or trucks
You can call Dimplex directly for Tech Support:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Feb 07, 2013 | Dimplex Compact Electric Flame Stove...
I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
1-888-346-7539
Monday - Friday
Nov 28, 2012 | Dimplex DS4411 Electric Heater
Dimplex optiflame remote not working
The DFI2310 uses a simple plug-in remote.
You can either order one from Dimplex, or use an aftermarket solution such as this one from Skytech: Skytech 1315G Electric Fireplace Remote.
Oct 08, 2012 | Dimplex DFI2310 23 Inch Deluxe Electric...
Bulb blew in my dimplex michigan fire, model MCN20. I now can't get the bulbs to switch off with either the remote control or the on/off switch.
Stewart, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON and set the function controls manually (not with the remote) one at a time. If everything works as it should, the fire reset itself during the 12 - 15 minute timeout. If it didn't or that problem continues to reoccur, contact Dimplex North America, Technical Service at 888-346-7539.
Hope this helped you solve the problem.
Apr 27, 2011 | Heating & Cooling
Hi I have a Dimplex electric fireplace model# CS3311. I had the Remote Receiver plugged into the wall outlet and the Unit Plug was plugged into the side of the Remote Receiver, just like it says to do in...
Lisa, apparently there was an electrical overload in the receiver box. I assume this electric stove is new and still under warranty. In which case, armed with your Proof of Purchase, you need to contact Dimplex USA or the retailer you purchased it from.
Below is a link to Dimplex USA Customer Support.
http://www.dimplex.com/customer_support/contact_us
Feb 23, 2011 | Dimplex Compact Electric Flame Stove...
My dimplex has a remote control box that plugs into the outlet. I haven't used it for a year or more. smelled something hot when it was on. the outlet & box was very hot, the bottom of the box was...
Feb 07, 2011 | Heating & Cooling
Remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Dec 13, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
1,148 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
