Question about Whirlpool Dryers
Hi, I actually have a TGDS840PQ1. Anyway, my
Hi, I actually have a TGDS840PQ1. Anyway, my problem is this.... The dryer DOES heat up. But when the cycle is complete, the clothes are still damp. Like they just don't dry completely. I've cleaned the lint filter and pulled the venting hse to be sure its free from lint and it is. So any thoughts on why the dryer wont completely dry the clothes? Is there a blower that pulls the air through the dryer? Cause it doesn't seem to be venting the air anymore. I guess I would compare it to a sauna. The warm air goes into the dryer but its not venting out. So thats why the clothes don't dry completely. What's causing the air not to vent?
  • Whirlpool Master
  • 43,501 Answers
Hi
I think you need to check this tip out...
Dryer Maintenance
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Posted on Aug 07, 2010
Can I get a list of error messages for an ASKO TL751 clothes dryer?
I googled: Asko TL751 Electric Dryer Error code HI
You may find a manual in this search that gives you the code
If I had to guess it means the high heat is not working, or the high
temperature protection has opened to protect the dryer from
self distruction.
Your owner's manual should give the error codes.
No manual? manualslib.com may have it. YOu may want it next time anyway.
Mar 31, 2015 | Asko TL751 Electric Dryer
Dryer not tumbling
It's probably the belt that turns the drum. They're easy to change and inexpensive too.
Oct 30, 2013 | Whirlpool Traditional Electric Dryer with...
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
Dryer runs but does not heat up?? The actual model number is WGD5500S
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 16, 2010 | Whirlpool WGD5700S Dryer
My Maytag Alliance gas dryer won't heat up at all. The dryer keeps running due to the temperature not changing. There is no heat at all. I ran out of propane - the dryer stopped during the cycle, the...
heatman101
Sep 05, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
No heat
Well first of all you can tell us the model number of your dryer, so we can help you...... anyway if your dryer is a electrical dryer then first you check Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please post comments for further help or information..........
Good Luck!!
Mar 28, 2010 | Hotpoint Dryers
Dryer will not dry - hte heating element has just
check the hi-limit and cycling switches on the element case and the thermal fuse on the vent ductwork
Mar 12, 2010 | Dryers
No heat in Dryer
Hi, this Maytag dryer has a set of malfunctioning coils that will need to be replaced. This coil assembly is located on the actual burner assembly.
Please rate and god bless:)
Apr 14, 2009 | Maytag Dryers
GE dryer tumbles, but there's no heat
Hello coylejm, Thank goodness, 220v has a BAD reputation. Your hunch is correct. To confirm use a DVM to check the heating elements conductivity. Open one terminal of the element and measure ohms of the terminal. A very unlickley chance you damaged the control box. Merry Christmas.
Dec 13, 2008 | GE Profile Harmony DPGT750EC Electric...
ASCO T721 dryer, the heat temp is too low
Is your model a Condensing dryer or does it have a Vent to the outside?
Jun 11, 2008 | Dryers
Dryers Logo
111 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
