Windows 7 does not recognize my 80GB frecom mobile drive
  • 13,433 Answers
If this is a brand new drive it has not been partitioned and formatted.
in English, the drive has not been prepared for use. if the drive has worked before then possible problems are worn out power supply (if it uses one) - would need to be replaced. Or the hard drive has failed, if you hear clicking sounds or similar, the issue is probably a bad drive or in some cases the drive might not be getting enough power from the power supply and it just clicks because of that, in that case replacing the power supply would help.
if this is the first time you are using the drive it needs to be partitioned and formatted. right click on my computer or computer icon in your desktop or in the start menu, select manage. then on the left side click on disk management, on the right side, you may get a notification about the drive needing to be initialized. You need to partition the drive, right click on it and select create partition, simply click next next next, when you are given a option to check a box that reads QUICK FORMAT. click on it. this will save about a hour or more of your time.
after this the drive will appear and will be ready for use.
Posted on Aug 07, 2010
Fujitsu sata mhv2080bh 80GB drive partition in windows 7
Not sure what your question is but it seems like you are having some type of partition size issue with windows 7. I see that you say you have an 80GB drive which is very small so there is not much to partition on it.
Jun 05, 2012 | Fujitsu 50PK 80GB SATA 5400RPM 2.5 IN...
Windows 7 64bit
You can't find the drivers because you don't need drivers for it, and since Beyond Micro went out of business they have no support for the drive anymore. Time to drop kick that baby back to the stone age.
Jun 01, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Cannot install whs on ssd using flash drive
I would suggest cloning the OS install.
Install the OS on the 80GB SSD with the Foxconn board that is giving you troubles with the 40GB SSD. Then clone the drives and swap SSDs.
WHS 2011 probably will throw up a flag stating that it needs to be reactivated because of hardware changes, but it should go smoothly.
Dec 23, 2011 | Foxconn (M61PMP-K) Motherboard
I am trying to find out if a Sony Vaio with ATI Mobilty Radeon 9200 can be upgraded to Windows 7.
Sony Vaio VGN-A250 is a good choice.
  • Intel Pentium M 725 (1.6GHz, 2MB Cache)
  • 512MB PC2700 DDR Memory (2GB Maximum)
  • 80GB Hard Drive
  • 4x DVD+/-RW Optical Drive
  • 15.4" WXGA (1280x800) LCD and ATI Mobility Radeon 9200 with 64MB Memory
  • AC'97 Audio
  • v.90 56Kbps Modem, 10/100 Ethernet and 802.11b/g Wireless
  • Three USB 2.0, One FireWire, One Type II PC Card Slot and MS Slot
  • 14.8" x 10.9" x 1.8" @ 7.3 lbs.
  • Windows XP Home, MS Works, WinDVD, Quicken, Norton Internet Security, Sony Suite
It will be upgradeable to Windows 7 if you install more memory (2GB DDR Max.)
Aug 11, 2011 | ATI RADEON 9200SE Graphic Card
I have a Maxtor Personal Storage 80GB and my Windows 7 does not recognize it.
is this device being hooked up exactly the same way as your last OS , make sure you have both cables hooked up , make sure your
device is spinning up to the max RPM , if max RPM is not reached
the HDD will not work on any system , also if your windows 7 is
a 64bit version the utility disk that was provided will not work
from the old 32bit windows OS even if you were using windows
XP 64bit , go to Maxtor online inquire about 64bit windows 7 drivers
for that device .
Jan 14, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
Freecom external 80GB drive not detected by Windows
go to the freecom web site and download the drive for that unit after that the computer will see and connect to the unit
Oct 24, 2017 | Electronics - Others
I have a 80GB disk, but only 30GB is a recognized partition by Windows.i need instructions
Most likely the problem is that you have another blank partition. The Microsoft disk management tool can probably solve this. This is a tutorial on how to use it. http://support.microsoft.com/kb/309000/
Let us know if this works out for you.
May 24, 2008 | Excelstor Technology J880 Hard Drive
Harddrive problems
Was this 80GB cloned (copied) from an old 30GB disk?
Open Computer Management window doing this:
Start button - settings - control panel - administrative tools - computer management.
In the window that open, on the left hand side pane, expand Storage and click Disk Management. On the left hand side window, lower pane you should see a list of disks. See Disk 0,Basic <disk size>, Online. Do you see the 80GB as disk size? To the right you would see a series of boxes. Probably you see (C:) 30GB NTFS Healthy (system). Do you see to the right of it a box with 50GB (unknown partition)?
If so, you do have a 80GB disk, but only 30GB is a recognized partition by Windows. You can still use the the unknown partition. Post back here if you need instructions.
Dec 31, 2007 | Excelstor Technology J880 Hard Drive
Internal 80gb harddrive excelstor j880
Computers & Internet Logo
Alun Cox
David Payne
David Payne
