Question about Epson Artisan 800 All-In-One InkJet Printer
Epson 800 not recoginizing epson cartridges. My printer only recognizes them one at a time. When I have all installed it will not recognoze any and will not allow to prnt. Has been workig great but now it dosent work at all. Any ideas why this is now happpening. Help. Jb
  • Epson Master
  • 1,879 Answers
  1. VERY IMPORTANT: If your printer is still within its one-year warranty period (from the original date of purchase) please contact the Epson from 9 AM to 9 PM EST or 6 AM to 6 PM PST Monday through Friday (except holidays) when you are with your computer and printer setup.
  2. Basic troubleshooting:(you can do this on your own or with the EPSON tech)
  • Unplug it from the computer
  • After shaking (cover the hole where the ink comes out while doing this), put all ink cartridges in (mentioned:EPSON cartridges, good for you)
  • Use the printer menu for head cleaning, do this 3x consecutively
  • Use the printer menu to do test print
    If the issue still persists after the above test, straight answer: hardware malfunction, non user serviceable .
Posted on Aug 07, 2010
  • scorched Sep 07, 2010
    ohms apparently does not own this printer.
    First of all, if an Epson printer is not recognizing the cartridge shaking it will not help - the carriage is bad and this is a known issue. I had the same problem as have others.
    Secondly, If you do a cleaning procedure even once on an Artisan you will drain the cartridge if it is a standard capacity, and lose half of the ink in a high capacity cartridge if you try it 3 times. These printers are the worst in the industry for wasted ink on the cleaning procedure.
    Just call Epson and return the printer as many times as it takes to get a good printer. You will not get a new one, but a refurb.
    Insist on a set of high capacity cartridges and you may just get them. It took some calls to supervisors but I was able to get them. It is outrageous that this style printer is set up to almost completely drain the supplied cartridges in the initial priming operation.
    Save your money and invest in a CIS setup. This printer will cost an arm and a leg in Epson ink.
    Problem Solver:
  • 6 Answers
First, change your cartriges to new original cartriges and you will see if the problem is because of cartriges or no.
Posted on Sep 05, 2010
4 Suggested Answers
SOURCE: Epson R1800 printer won't recognize new ink cartridge
ughhhh I'm having the same problem... STUPID MAGENTA
Posted on Oct 13, 2008
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Posted on Apr 06, 2009
  • 526 Answers
SOURCE: "Ink cartridges cannot be recognized" when using genuine Epson
i had this happen to me twice with two different people, it is highly possible that your black inks are defective, its also highly possible that one of the other inks are causing this error. take them all out, and put one and see what happens, do this one at a time until you see something screwey.
also possible, the contacts on the printhead are dirty or are pushed in.
also possible, bad printhead.
Posted on Jun 27, 2009
Epson 1400 not recognizing an epson ink cartridge
not necessarily faulty cartridge - had same problem went thru various cartridges some worked some didn't - in fact they weren't epson - so bought epson from office depot and that would not work, so not an issue of ink dried up - if yr printer is fairly old may be easier just to replace rather than waste time and money on trying to figure out problem
Sep 13, 2013 | Epson Stylus Office Equipment & Supplies
Epson wont recognize black refill cartridge.
I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunately, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps.
Jun 26, 2011 | Office Equipment & Supplies
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges ' eHow.co.uk http://www.ehow.co.uk/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz1YgKjqw42
Instructions
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Mar 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Is it ok to remove the print head from an epson artisan 810 printer to clean it? Will allignment be a problem?
yes you can remove it. and dont worry about allignment you can software manually re-align it will recoginize it immediatly
Mar 22, 2011 | Epson Artisan 800 All-In-One InkJet...
My Epson NX415 does not recognize refilled and reset cartridges. What can I do about it?
Don't let your ink levels drop below 25% before refilling and resetting your cartridges. There is an inner and an outer chip on these cartridges. The inner chip disables the outer chip when it's contacts are no longer bathed in ink. So, it doesn't matter if you "reset" the outer chip after refilling your empty cartridge because the chip was disabled. I'm really curious how you refilled these cartridges yourself without souring yourself on refilling from the experience. I own a Cartridge World ink refilling store and I refilled a set of these cartridges when we had replacement chips available (we don't now because our chip distributor was violating Epson patents) and it was an absolute mess, took forever, and the cartridges still didn't work in our test printer.
Feb 13, 2010 | Epson Stylus NX400 InkJet Printer
My Epson 105 doesn't recognize my Epson 88 ink cartridges
please use only recommended cartridges found either on the upper portion of your printer or in the printer manuals.... take note of the code.
Jan 28, 2010 | Epson Stylus NX105 All-In-One Printer
Epson r340 ink cartridges not recognized
god pm my printer ako na epson r230 ang problem niya ay walang lumalabas na output paano irepair yong
Feb 13, 2009 | Epson Stylus® Photo R340 InkJet Printer
Epson R320 printer will not recognize any of the ink cartridges
I tried two things of which one solved the problem. I am not sure which. Secondly, I have an R260 printer which is a less featured member of the printer family uses Claria inks like R360 and R380. I called Epson and they simply sent me replacement cartridges for the two black ink cartridges with which I had a problem. My printer did not recognize these new cartridges either. I noticed that both the ones I bought and the replacement ones have a slot hole near the green chip on the cartridge. The empty cartridge did not have this slot. They just had some circular depressions. So, I put a piece of masking tape over the slot and tried again but still no luck. However, when I removed the cartridge, this time a small piece popped out. This piece connects to pins on both sides. So, it is obviously an interface between the cartridge and the printer. I pressed this piece back in, replaced the cartridge with the tape on it back it and, voila, it works. Most likely this interface piece was loose and simply pressing on the cartridge didn't get it in far enough or who knows. You maybe able to take thiis piece out and replace it or merely push down on it with a pen but first, flash a light on it first to see if it is not sitting awkwardly.
Dec 18, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Artisan 800 All-In-One InkJet Printer Logo
1,295 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
