Question about ZT Group CISNET A7022 PC Desktop
My computer shuts down for no reason if left idle for 10 minutes
  • ZT Group Master
  • 13,433 Answers
The computer might be set to go into stand by or hibernation after 10 minutes of not being used. check the power settings in start -> control panel -> power. (will probably have a different name)
another cause might be overheating due to dust in the fans - blocking the airflow.
Posted on Aug 07, 2010
2011 FLTRU Fuel injection or electronic throttle?
Sounds like the fuel pump is trying to seize (screeching sound). Loss of fuel pressure will cause shut down. Change fuel pump and fuel filter
Feb 27, 2018 | Yamaha Motorcycles
Truck shuts off
Sounds like a fuel sensor either fuel pressure tank pressure or a bad fuel pump either way it seems your fuel pump is shutting down. It could also be related to the security system scan the vehicle for sensor codes or security faults also if the ignition key is worn it could cause the computer to read it as a bump key and activate the anti theft system
Apr 11, 2014 | 2000 Toyota Tundra
2003 sierra gauges not working plus dash plus drains my battery any suggestions ?
Try this simple trick. Shut off every thing in your vehicle, radio, ac, lights, windshield wipers etc.Turn off the vehicle put it in park. Disconnect your battery , wait 5 minutes. Then Without turning any thing on leaving the vehicle in park reconnect the battery start the vehicle and let it Idle for approx 10 minutes. This allows your computer to reset all of your gauges. By assuring that everything is off your computer can concentrate on resetting everything correctly without missing a step . This will set your Idle and all of your Gauges. Whenever your battery is disconnected for what ever reason this step should be followed immediately upon reconnect.
Nov 16, 2012 | 2000 GMC Sierra
I have a 1986 Chevy S10 with a 2.8 V6. Has issues idling sometimes one minute it will want to die and the next it will idle fine. When it is wanting to idle rough the brakes get stiff. what could the...
Do this
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
Nov 05, 2012 | 1986 Chevrolet S-10 Blazer
My Sony VGN-CR590 shuts down after 5-10 minutes. How can this be fixed? I'm not sure the fans are running.
A way to check to see if the machine is overheating is when you turn on the computer, there should be an option to hit F10 or F2 for the bios. In there, there should be a few temperature readings. Let the machine idle and in the bios if the tempature rises in there there could be an issue with the cooling for the CPU.
Jul 11, 2012 | Sony VAIO VGN-CR590E PC Notebook
Shuts down going down the road shuts off completely
vehicle shuts down while driving down road and does not start backup for at least 20 minutes, could be a bad crank sensor. if bad it will start and run fine, but it will keep shutting down until fixed.
May 16, 2010 | 1997 Nissan Pathfinder
The Startup repair program is running and wont stop
A complete scan can take several hours to complete. If you want to shut it all down unplug it and remove the battery. Leave the battery out for at least 10 minutes, and until it cools down.
Nov 04, 2009 | Computers & Internet
Iphone shuts off by itself
It is the phone power saving mode. You should set it to maximum time if you don't want your phone to shutdown rigthway when idle. Go to phone settings do it.
Nov 03, 2009 | Apple iPhone 3G
My Gateway 7510GX shuts down after ten minutes. I
i think there are two causes for this reason.1/ ur processer fan is not working properly. at that time u should get this message as thearmal heat. then ur computer shutdown. 2/ setting of power option my be fixed 10 minnutes. we should kee poweroption always never shutdown.
Jun 11, 2009 | Gateway 7510GX Notebook
ZT Group CISNET A7022 PC Desktop Logo
107 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
Jose Pino
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
