Question about Weber Grilling
We have a 3 year old Summit - gas will not light. Gas line is fine - no kinks. Cannot light any burners with matches. What could be the problem?
  • 140 Answers
Replace the Regulator you can get that at home depot
Posted on Aug 19, 2010
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Ignition button not working, however the bbq will light with a match. I have replaced the old gas bottle and this is still an issue?
Sounds like you need to replace the igniter. If the gas lights with a match, there's nothing wrong with the gas bottle. line or burner.
Jan 28, 2014 | Weber Baby Q Grill
Front right burner on ge jgs968 slide-in gas range wont light
First you need to find out if you have actual gas reaching the element. Can you light is with a match. If you can't light it you have a clogged gas line and will need to find out if it is the tip or the line. If it does light with a match, then you will need a new lighting element.
Jul 10, 2013 | Kitchen Ranges
Caloric range oven, older at least 20 years old, the range burners spark, but will not light, i am assuming that its electronic ignition, no pilot light?
If you don't smell gas, then it is probably electronic ignition and not a pilot light.
But if your oven and none of the range burners light, are you sure you are getting gas to the unit or from the range valve to the burners and oven? Can you light the burners with a match? If you can you can rule out the valve and incoming gas line, and concentrate on the ignitors.
Jun 07, 2011 | Kitchen Ranges
The grill will not light
It may be the regulator replace that and you should be ready to go!
Jul 06, 2010 | Weber 2780001 Summit S-470 Gas Grill
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will...
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Aug 26, 2008 | Kitchen Ranges
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
High performance burner slow to light
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Nov 26, 2006 | Jenn-Air JGC8536 Gas Cooktop
Grilling Logo
42 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
