I keep getting error message 3802. I've unplugged the printer several times. I got this after installing a new black cartridge. Thank yoiu Phil Klaver
SOURCE: Lexmark all in one 4270 won't print in black
I know your problem. I just put in new cartridges and it will print the test page, but nothing else. Did you get an answer
Posted on Sep 12, 2008
SOURCE: Dell Printer 926 cartridge error
I had the same prob..... I fixed it I took a clean soft rag sprayed Windex on it wiped off the ic type board on the front of the cartridge and also the board on the inside that the cartridge rest up against,,, turned it off and on put a copy under the scanner and kaabam it printed a month of pulling my hair out it works
Posted on May 22, 2009
bob_computer
  • 3153 Answers
SOURCE: error 3802 how do i fix it?
You should take it back and exchange it or read on below.
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the internet or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well
Posted on Sep 11, 2009
  • 1382 Answers
SOURCE: "incorrect black cartridge installed"
To fix this problem first you have to do a hard reset by pressing and holding the cancel and the left arrow while plugging in the power cord. This performs a partial reset which will give access to the country and region settings if they are available.
If that doesn't solve your problem uninstall and reinstall the driver. Its always possible that you may have an actual hardware/parts problem in the printer. To uninstall the driver first you should open your "Control Panel Utility", then open the "Add/Remove Programs", then under "Install/Uninstall", highlight and "Remove" any old printer drivers that may already be installed. Sometimes the same older drivers can be corrupted and conflict with newer drivers. I suggest downloading the latest version from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&os=20&product=57769&lang=en
Thank you !!
Posted on Jun 10, 2010
lacroixx1
  • 101 Answers
SOURCE: Printer not printing black ink after replaced ink
DID you remove the small tape sealed on bottom of cartridge?
also check for dried old ink sploch in cartridge cradle bottom
right click printer use the printer utilities to clean print cartridges and align the cartridges nost printers have utilies or tools to assist
Posted on Jun 13, 2010
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Printer will not clear the Error 3802 , what do I do?
Hello and Welcome to FixYa!
Error 3802 generally occurs in the Kodak Inkjet Printers.
To solve this error Turn the printer off and then turn on, this problem is solved by doing this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If you are still facing this then do it again almost five times & if still your problem is not solved and you still get error code 3802 then probably your KODAK EASY SHARE 5500 All-In-One Ink Jet Printer is in need of servicing by a service professional.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you and Keep using FixYa!
Aug 17, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Getting problem code 3802
Hello thanks for using Fixya
Error 3802 Mean Print head Failure
Turn the printer Off and On, This problem is solved by this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If the problem still there then do it again almost five times & if still problem not solver and you get error code 3802
then it is probably that your KODAK Esp 3250 Allinone Multifunction Printer is in need of servicing by a service professional.
So go to the KODAK Service Center
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation "if it is helpful"
THANKS
Keep Using Fixya
Feb 28, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Thank you !!
Jun 10, 2010 | HP PSC 1610 All-In-One InkJet Printer
Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
Mar 08, 2010 | Lexmark P6350 All-In-One InkJet Printer
Error 3802 how do i fix it?
This is a printhead error message.
Reseat the printhead severly times. If the problem persists, you need a new printhead.
May 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
k24674
jasbo
jasbo
Marvin
Marvin
