Question about Hotpoint Ultima WF860 Front Load Washer
My Ultima WF860 keeps displaying F-01. I also want to check that the pump is clear but don't know where to find it?
    President:
  • 1,382 Answers
"Error F01"is indicating that the motor triac has short circuited on main PCB, this is part of the electronic speed control for the motor.You can do simple checks like motor connections/brushes etc.If the connections are seems to be perfect check the wiring whether it has continuity from motor to PCB. If there is no continuity then the PCB is faulty.Hotpoint's advice is to call an engineer, it is not really a DIY repair, unless you have a good knowledge of electronics.
Thank you !!
Posted on Aug 07, 2010
Where the pump on a hotpoint ultima wt960
Unfortunately the manual link won't help on this problem, it doesn't give the answer. However if you remove the rear panel ( plastic and two screws ) where the waste hose comes out, the motor will be seen on the left, the pump is on the right at the bottom corner. Hope this helps, I am unable to go further as I don't know the problem.
Apr 25, 2012 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima Washing machine - When I switch it on all the lights keep flashing and I can't get rid of them !! When the machine then starts the cycle it still flashes but then stops half way and says...
I would advise you to check the drain outlet hose for a possible blockage, or the pump itself could be blocked or faulty.
Drain any surplus water in to a bucket or similar before removing hose or pump.
Also try resetting washer if there is a reset button, hold it in for at least 3 seconds, this should clear any programme held in the memory.
Hope this helps.
Feb 01, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
My machine is flashing F-01 Hotpoint ultima WT960
so is mine 3rd August 20:20. I hope it is ok because sods law my warranty has just expired!!!! What does F-01 mean?
Jul 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius ultima 1000, when wash cycle is comple the rinse cycle wont start and displays message check outlet pipe which i have done but it seems to be clear as i can syphon water from the machine...
It sounds as though the pump is not draining the water out.
If you have checked outlet pipe and it is clear, then you need to check the filter, if there is no filter at front of m/c, then remove the rear panel, and unfasten the large black hose that goes to bottom of drum, remove filter and clean, check pump at same time.
Watch out for water from the drum.
Refit filter and hose and test.
Plz rate my suggested solution, and feel free to leave a comment.
Thankyou.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Ultima 1000 wont spin
there may be a blockage at the pump end of the drain hose or the filter.
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
439 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
