Question about Refrigerators
Side by side refrig by kenmore and refrig running but not cooling. freezer is fine. checked settings.
  • Refrigerators Master
  • 3,051 Answers
Hello there:
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running. First, answer these questions: Is the thermostat knob turned to the proper setting? If not, reset it. Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these: The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor Cooling is poor A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Posted on Aug 07, 2010
  • Michael Thomas
    Michael Thomas Aug 07, 2010
    Evaporator coils
    Poor
    coils. You can't see these coils without removing a panel on the
    inside of your freezer. A sure sign that there is a build-up is the
    presence of any frost or ice build-up on the inside walls, floor, or
    ceiling of the freezer. Such a frost build-up usually indicates a
    problem in the self-defrosting system or damaged door gaskets.
    The
    refrigerator is supposed to self-defrost approximately four times in
    every 24 hour period. If one of the components in the self-defrosting
    system fails, the refrigerator continues to try to cool. Eventually,
    though, so much frost builds up on the evaporator coils that the
    circulating fan can't draw air over the coils. There may still be a
    small amount of cooling because the coils are icy, but with no air flow
    over the coils, cooling in the refrigerator compartment is quite
    limited.
Refrig not cooling?? freezer is fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 22, 2011 | Kenmore 53603 / 53606 Stainless Steel Side...
I have a Kenmore top freezer refrig, My freezer works fine. My fridgerator is not cooling. I can hear the fan running. What could be the problem?
heatman101
May 26, 2011 | Kenmore Top Freezer Refrigerator
Freezer side is working normal. Refrig. is not cooling .temp set is on more cool side. I cleaned condenser. Light bulb off during closing.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Kenmore Refrigerators
Refrig compartment does not cool on my new Kemore Frig.
Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
Feb 28, 2010 | Kenmore Refrigerators
I have a Kenmore side by side refrig (no ice maker) Freezer works fine. The refrigerator side is not cooling. I have cleaned out the vent between the freezer and the refrigerator section by defrosting the...
Check to make sure the evap fan is running.
IF so, then let unit defrost, then turn back on, check for air comming thru top of refrig vent, if air moving ok, then let run for a few days and see if refrig warms again, if so then check for frost build up on back wall of inside freezer, if so, you have a defrost problem. With a defrost problem, defrost heater may be bad, defrost timer/electronic control may be defective. Either way, in most cases it is a defrost problem unless you don't have air moving and fan is running in this case you have a damper door problem inside air duct in refrig.
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator won't cool, but freezer does.
by closing that small door you are starving the refrig of cold air . you should be getting a heavy whisper of air through that door. place all controls in the middle position, close the freezer door and check for airflow through that vent.
Feb 24, 2008 | Refrigerators
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
