Question about Neff B1432 Single circotherm plus Electric Oven
Neff b1432n1gb/07 door drips constantly when in use
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 15, 2010
How do you take the doors off Neff double oven
fully open door and lift up small metal stirrups on bottom of hinge then close door up to them grip door firmly and lift upwards ,there are videos on you tube for this also.
Feb 09, 2017 | Neff Ovens
How to remove door to Neff Combination oven C57M70N3GB
you can remove the door but due to its construction it will need to be checked by technician to make sure it doesnt leak energy after repair.
Oct 12, 2016 | Neff Ovens
I have had both door hinges replaced on the main oven of my Neff but the door still does not close properly. What is the next step?
I would have gone straight through Neff. If it can't be fixed, your'e supposed to get a new oven out of the deal.
Apr 29, 2012 | Neff U1461 Double circotherm plus Electric...
Er 07
i can't help you with this brand but in almost all oven of this type . inside behind the display board is a tech sheet. it will have all the answer's fault codes are a common way for self diag ovens and other appliances .. mm
Jul 14, 2010 | Neff B1421 Electric Single Oven
My outer glass on door has shatter by its self can it be replace
You should be able to obtain a replacement door glas, they are usually supplied as a seperate item.
Try the following.
WWW.ESPARES.CO.UK/NEFF
WWW.NEFF.CO.UK/CONTACT.HTML
Mar 07, 2010 | Neff B1421 Electric Single Oven
NEFF oven U1461 - The bottom oven door hinges do not have enough strength to hold the door fully closed. Can these be adjusted and is this something I could do myself?
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Please rate my solution.
Thanks.
Nov 05, 2009 | Neff U1461 Double circotherm plus Electric...
Door does not close tightly ? problem with bottom hinges
Yep, sounds like the hinges/springs have been overloaded.
Dont know if it's a Neff problem in particular, but I had a Neff oven with exactly the same problem - it was already installed when I bought my house.
Spoke to Neff who advised this ocours if heavy things like a roasting tray with a heavy bird / joint in it is rested on the door whilst it's open.
Only cure is new spring/hinge units which are not cheap !
Sep 18, 2009 | Neff B1421 Electric Single Oven
Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Mar 12, 2009 | Ovens
Neff Oven Door Removed Incorrectly
you need to lock the hinges to get the door back.
it needs some strength
lay door flat on floor
force hinge against the spring until right back and put the locking arm over. i use my feet for this!
Nov 29, 2008 | Neff B1421 Electric Single Oven
Neff B1432 Single circotherm plus Electric Oven Logo
64 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
