Question about Maytag Washing Machines
Looking for wiring diagram for w10 Primus front loader washer
5 Suggested Answers
venexcsd
  • 1185 Answers
SOURCE: my frigdaire front load washer ate my underwire bra wire
Do not attempt to remove a drum unless you have been trained to do so
First thing to do is to dump the back drain hose into a big dish and drain off all of the standing water
in the machines sump.
Remove the power !!
Tip the machine towards the back and front to get as much water out of it as possible
Tip the machine back agains a wall or a bench with a cloth protecting both surfaces
Put a wooden block underneath the front edge of the machine in case it falls on you
Get a torch and look at the bottom of the drum , there will be a big hose connected to the base with a jubilee clip or spring clip
Remove the clip and pull the hose off , place a cloth on the floor as there may still be some water in the hose , if you are lucky the wire will be either in the hose or in the sump that the hose is fixed to.
If the hose is connected to the rear of the drum tip the machine as far back as possible allowing the wire to fall within reach of the hole
If you cant see it get a magnetic retriever or a piece of bent coat hanger and go fishing.
If the hose is fitted to the front of the drum reverse the machine and lay it on its front or as far forward as possible , that way the wire will fall towards the hole
Posted on Jun 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: looking for a seal kit for a 25lb. primus washer
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
  • 10 Answers
SOURCE: Looking for wiring diagram for
Hope this Helps:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5156511
Posted on Oct 05, 2010
SOURCE: WIRING DIAGRAM FOR A FRONT LOADER WASHING MACHINE
Diagram of internal wiring of ariston AV41washing machine
Posted on Mar 20, 2011
I have Samsung front loader washing machine that stop working suddenly there is no power no nothing and I checked power supply and nothing wrong with power supply .
Your power supply normally connects to an EMI filter immediately upon coming into the washer. If you have a voltmeter and are comfortable with electricity, you should remove the top cover of the washer to access the connections. Unplug the washer and shut off the water while dismantling. Remove the 2 screws at the back of the top portion (lid) and push the lid towards the back to dislodge it.
At this point, you should be able to locate the incoming power cable and see where it connects to the EMI filter. Once you have identified the connections, plug it the washer and verify that there is voltage both before and after the EMI filter. If there is no voltage at the incoming side of the filter, then your cable is broken and should be replaced. If there is voltage on the incoming side of the filter and none on the outgoing side, your filter is open circuited and should be replaced. If there is voltage at all locations, look for wires that may have shaken off during operation. When poking around inside the washer, looking at wires, pull the plug first. If this does not help, take a picture of the schematic diagram that is affixed to the top of the soap dispenser/water inlet box and post it for our reference. I have attached a typical diagram from a older Samsung washer. section-yodzb2tavlblrpvbck4ieuwo-2-1.jpg
Jan 10, 2015 | Samsung WF337AA Front Load Washer
REPLACE PROGRAM UNIT WIRING
wiring diagrams are difficult to get unless they are released by the company itself sir.
so we cant assure you of getting one.
bu we wil try our best to get you one.
Jun 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My primus 25 lbs w10 everything work but the motor dont turn
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Sep 04, 2012 | Cars & Trucks
Wiring Diagram for connecting ccu
If you are referring to a Whirlpool Duet, Kenmore Elite or Maytag Epic series FRONT LOADER, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and WIRING DIAGRAMS.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Oct 21, 2010 | Washing Machines
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
GE Front loader
My washer has the same issue. I am also looking for a manual.
SK
Mar 28, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Need to know what parts i need.
please go to this site. it has blown up diagrams for your washer and you can find what parts you need by "mousing over" the diagrams.
www dot applianceparts dot com
Dec 29, 2007 | Washing Machines
Washing Machines Logo
254 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
