Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Hi i am getting an error message clinkn connect can't discover router. please check the cable connection and make sure the router is powered on
    Scholar:
  • 104 Answers
This could be a cable fault.You can buy simple cable checkers at aPC store.If this isn't faulty,try uninstalling and then reinstalling the disc that came with it or going to device manager clicking on modems and seeing if your router is there if it is right click on to it and click update driver.RESTART THE COMPUTER.
If this didn't fix it,try unistalling the modem from device manager restart the computer and the windows system will try to find a driver for the modem.Or you could try searching for the driver in browse when you update the driver.IT GETS COMPLICATED I KNOW I'VE DONE IT THOUSANDS OF TIMES.WINDOWS 7 IS A GOOD OPERATING SYSTEM THAT FINDS DRIVERS AUTOMATICALLY FOR YOU.
IF YOU AINT GOT IT GET IT NOW.UPDATE YOUR PC.
Posted on Aug 07, 2010
Roku 1 setup
There are several factors that will affect or can cause problems in connecting your Roku to your Router.
If you're getting an error message on Roku like 014, 011, make sure to indicate it in your response. Normally, if you're getting 014 message, you can follow these steps:
. A simple power cycle resolves most of the issues. To perform a power cycle, please follow the instructions below:
1. Unplug the power cables from the modem, router and the Roku player.
2. Connect the power cable to the modem (after a minute). Once all the lights on the modem are lit, plug in
the power cable to the router and then to the Roku player.
3. Go to "Settings" and redo the complete Roku setup.
If the issue continues to occur, please try the channel 1 or 3. Should it persist, you may reset the Roku
player. Here is how:
On the back or bottom of the Roku unit, you should find a recessed little hole.
- Use a pin or paperclip to press and hold the button for 30 seconds (please ensure that the power light
blinks while you are holding it down).
The Roku device will reset to default and be ready for setup again.
If the problem continues, please reflash the software via the secret screen:
1. Press the "Home" button for 5 times.
2. Press the "Forward" button for 3 times.
3. Press the "Rewind" button twice.
4. Choose Update Software and the Roku player will then restart.
You can comment your serial number or the error message that you're getting. If your getting 011, just power cycle your entire network. Also, please make sure that you're not connecting the Roku to a Guest network. The speed of your connection matters as well. It should be atleast 1.5mbps.
Jan 27, 2014 | Linksys Computers & Internet
Help with d-link router please
Thanks, konafaa. Sometimes the best procedure is to start over from the beginning, as you discovered.Best regards!
Apr 19, 2012 | D-Link Computers & Internet
Installing a netgear router
It seems that you need to reconfigure router ,you can use following steps to reconfigure router
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
May 17, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
I have been using the Belkin Wireless G Plus router for days. All of a sudden it says a network cable is unplugged. Advice please!!
Check the connection between the computer and the router.
If your computer is connected to the router with the cable then make sure that there is no loose connection.
If your computer is connected to port 1 on the router then you will see the light on port 1.
If the light is not lit up then try another cable.
If your computer is not connected and you are using it wireless, then do no worry about this message. This message is for the wired connection.
Make sure that your computer is connected to the wireless network. Go to network connection, you will find wireless network connection. check the status of the connection.
Click here for more information about router and networking
May 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Had 3 d-link routers that keep giving off the error message that the "network cable is unplugged" all different models at different locations connected to differnt computers any ideas?
Hi, either there is a broken cable or faulty connector some where or the Lan card in your pc is faulty.
1/ Check all cables
2/ start with one router and connect that up by its self, without any other router.Connection should be made as close to the pc. You know the usual setup, modem,router,pc.
We are trying to narrow it down.
If pc still says network cable unplugged then make sure the lan card, in your pc is seated properly.Are you using a seperate lan card or the the motherboard connection.
I have just found that this product was discontinued in 2003,you are probably better of buying a new one.
But any how let me know how you get on.
Regards - Anthony
Jan 07, 2010 | D-Link (DI-711) Router
I keep getting an error message when i set my router up
The LAN cable maybe faulty, try a different LAN cable.
Jan 04, 2010 | Linksys WRT120N Router
Internet conection
Try to check the other end. It could be a loose ethernet cable connection. Make sure you hear the click sound. That means the RJ-45 connector is properly inserted. If you have a spare cable, you can try to change it also.
Sep 05, 2009 | Acer TravelMate 240 Notebook
How to Install DLink DIR-615 with only 1 port on my laptop?
Connect the modem to the router via the ethernet cable. Connect the laptop to the router by means of another ethernet cable in one of the 4 spare sockets. Switch everything off. Turn everything back on one at a time, modem first, then router, then laptop. Allow each unit to fully power up before switching the next one on. Put the installation CD in the laptop and try again. If you are using the laptop wirelessly, make sure the wireless function is switched on!
Apr 12, 2009 | Computers & Internet
Still not connected
vhevk your ethernet cable wire.
if u connect router to swithc then use straight cable.
if u use router to computer use cross cable.
Jan 10, 2009 | Linksys Wireless-G Broadband Router
WRT54GX4 Wireless Router Setup Problems
Hi Randy
Reset the router
Use regular way to configure the Router.
In computer side
Go to Start>Connect To>Show all connections
a new window (Network Connections) will open,
Right click on the "Wireless Network Connection"
Click on "View Available Wireless Networks" You will see "linksys" with the highest signal level. Connect it
after connection go to web browser; type 192.168.1.1 and hit enter. It will take you to Linksys setup page which is integrated in the router. after that you can do any settings you want.
Please post here if you need further assistance
Good Luck
Jan 12, 2008 | Linksys WRT54GX4 WIRELESS 802.11G...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
126 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
