Question about Mitsubishi WS-48613 48" Rear Projection Television
Mitsubishi WS48613 I have a flashing green light. TV wont come on. Pressed system reset with the same results. Television has worked fine.....that is up until this morning. I have no user manual.
  • suzettelan Nov 28, 2008
    can you please help with this problem?
  • Mitsubishi Master
  • 8,617 Answers
You need to replace the 4 100uf capacitors on the DM board. You can get the service manual for your set at this link. They will email it to you after purchase and they will provide free instructions on how to do the repair with pictures plus free on line tech support . heres the link.
Posted on Apr 27, 2008
This sounds ridiculous but try holding a hair blow dryer to the back of the set. It needs to get warm inside the set. I will never by a Mitsubishi again! My tv is years old and should not have problems! This solution will work until you fix it or buy a new tv!
Posted on Nov 14, 2009
Tv problem
can you tell in what patter does the light blinks??
Mar 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi tv keeps turning off.
Hello there please check the following in your tv;
Reset the component settings. Most problems with Mitsubishi projection televisions can be resolved by resetting the television to factory settings
If this does not work then a full system reset should be performed on the control panel by pressing the System Reset button. The television will turn off and the green LED light will flash quickly for a minute. When the light stops flashing, the TV will turn on.
If that still doesn't work, then the projection lamp might need replacing and here is how to do that;
Ensure that the bulb is completely cooled and the television is unplugged. Use a Phillips-head screwdriver to remove the lamp compartment cover. Unscrew the lamp cartridge on the rear of the television. As opposed to the cover door, these screws do not actually come out of their chamber and simply loosen the lamp assembly. Remove the old cartridge and insert the new one. Secure the lamp with screws, then replace the cover and screw in tightly.
Please note that, Finger oils can cause the lamp to malfunction.
Projection lamps are powered by mercury. Wash hands thoroughly after replacing the projection bulb.
Jul 04, 2010 | Akai PT61DL34 Television
Ws-55813 mod. green ld light wont stop blink tv wont turn on
The DM modul is bad. Replace all 1000mF/16V capacitors( be careful with the polarity). After replacing capacitors conect to AC power. Waith about 1min. Green flashing will stop. Turn ON tv. The modul is on the raight hand side next to the main board.
Jan 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws-48613 no power
It seems problem of weak capacitors in power supply and deflection board.
If you have little experience of TV repair and good soldering skills, then check above said boards for weak capacitors.
You also need to have service manual of WS48613 which can be obtained from Manual Zone.
Service manual has schematics and technical information of TV to help in repair.
Dec 12, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Power problem
Most likely the convergence ICs are bad. These aare large black ICs attached to a heatsink. They will be marked STK393-110 and have about 15 pins or so. Replace these and check the fuses marked F9A01- F9A06 on the same board. Replace any open fuses after the IC replacement and report your results here.
Apr 21, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WS-48613 48" Rear Projection Television Logo
174 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
