Question about PfaFF Quilt & Craft Pro 7530
My needle keeps breaking while I'm trying to machine quilt. It also at times will collect the thread on the other side of the quilt which makes me think something is wrong with the bobbin.
Q1.(A) Without realising, you could be 'helping' the material feed.
Q2. (A) Is the thread collecting at the start or during sewing?,,if at the start, make sure threads are clear and hold them out the back of work gently till a few stictches are made.
If during sewing, it could be tension isn't adjusted correctly, experiment.
Posted on Apr 28, 2008
I am quilting and the thread keeps breaking. What is the problem?
Not sure if you are piecing or trying to free motion quilt. If FMQ, try using an Embroidery needle (it has a groove in the shaft that helps protect the thread) or a Topstitch needle. Make sure the thread is not too thick for the needle's eye. Check to make sure the upper and lower tensions are not too tight. You might try changing brand/type of thread.
Here's a needle guide:
SCHMETZ Household Needle Chart
Or review suggestions for breaking thread here:
Why is my thread breaking
Hope this helps!
May 20, 2015 | Sewing Machines
Free motion quilting bobbin thread come to the top
check the timing between the needle and rotating hook also check the teeth for possible lost of timing maybe low or high to much.
Nov 06, 2013 | Brother CS6000i Computerized Sewing...
Broken and bunched thread on back of fabric
try changing the needle
also try adjusting the top thread tension and see if that helps
make sure the top thread has not come off the thread take up lever
also the machine may need to be checked for a timing problem.
Nov 28, 2012 | Sewing Machines
I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
Nov 17, 2011 | Sewing Machines
I have a Janome 1600P DBX. The needle is installed correctly but the thread on top keeps breaking or skipping stitchings while free motion quilting? the quilt shop says it is not out of time. I have...
Is it a new needle? a dull needle or one with a burr on it can cause those problems that you mention.The kind of needle you use is also very important. I like to use a 70/10 or 80/12 jeans needle depending on how thick the thread is.
Apr 20, 2011 | Janome 1600P-DB Mechanical Sewing Machine
Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Sep 23, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
Thread breaking
Dec 09, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
142 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
