Question about Scanport H21 21" LCD Display Monitor
Ineed to buy power supply board 710 n - Scanport H21 21" LCD Display Monitor
    Genius:
  • 1,196 Answers
If you are looking for where to buy power board on your monitor, i will advice you go to any computer accessories shop around your locality to get the power board or you can order online from amazon.com.
Take care.
Posted on Aug 12, 2010
Why does my TV turns itself off?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 18, 2015 | Hisense 710 Series 55T710DW 55" LED TV...
Honeywell hz-710
Hello, welcome to Fixya!
Your unit is having a power fault because it is not switching on. The unit might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the receiver.
If plugging into another power outlet doesn't power it on then it confirms that the unit is having a power fault.
When electric current comes from the power outlet into the unit, it goes straight into the power supply board which then circulates the current into the unit. So if the unit doesn't power on, the first thing is to make sure there is power entering into the unit.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board. Once you detect any bad component, you can make necessary replacement at any electronics accessories store within your vicinity. This is the only way by which you can detect and solve the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.
Nov 05, 2012 | Honeywell HZ-710 Oil Filled Radiator...
Ot 710 network key
ot-710
352803040964737
Feb 11, 2012 | Alcatel Cell Phones
Ineed code number to pair my bluetooth
try '0000'
that is code for most headsets
good luck!!
Apr 07, 2011 | LG HBM-710 Wireless Headset
How to connect the power supply cables to motherboard?
Accordhttp://webcache.googleusercontent.com/search?q=cache:cn4FgQtjuTgJ:www.intel.com/support/motherboards/desktop/sb/cs-020836.htm+how+to+coonect+power+supply+with+945+moter+board&cd=1&hl=en&ct=clnk&gl=ining to *********** board.................this link wil hepl you.
copy and paste above link on the web browser. and get your solution.
JAIN_IT
Sep 08, 2010 | Gigabyte GA-945GZM-S2 Motherboard
My toshiba tlp710 projector wont power on
check your power cord first, if good, if not replace it. if the problem still occur, check the power supply board of your projector. and replce it.
jahting
Oct 08, 2009 | Toshiba TLP-710, TLP-711, TLP-G5, TLP-G7...
Ineed the voltage and connector polarity for the ADS TV ELite Pro
I just found one too, same situation... no power supply. Mine has box and all. On the back of the box, it reads:
Power Supply 7.5 VDC power adapter
It doesn't say what polarity, but judging from the board... I'm gonna' say + in the center. That's what I'm gonna do.
May 31, 2009 | A D S TV Elite Pro/w Remote (TEP-100R)
Power suply
Go to www.tigerdirect.com and order one. I suggest going about 25% higher in watts than the one you had.
May 29, 2009 | Dell POWER SUPPLY Power Supply
Where do I buy Sharp Aquos parts. I am after power supply board. CA009WJN1 for Model LC-30HV4M Thanks
Good Day, coopsl;ine;
Try calling (630)-226-2699; SHARP, or go to NATIONAL PARTS CENTER: parts@sharpsec.com. Good luck, big IRISH.
Sep 09, 2008 | Sharp Televison & Video
Scanport H21 21" LCD Display Monitor Logo
120 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Jerry Umali
richie46
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
