Question about Whirlpool LER5636P Electric Dryer
Admiral Dryer will not heat
I assumed the reason was the heating element was no good, however when I went to remove the element I found the wire on the lower left ( I assume this provides power to the element) had been burned and melted off of the connector. I replaced the connector and re-connected the wire to the heating element. This worked for about 1 day. Again no heat. The same problem the wire is melted off the connector. What do you think is the problem??
Fixya is worthlessya!
Posted on Oct 25, 2011
  • 770 Answers
Bad connection
this wiil cause this make sure to use a Hi Heat connector abnd the connections are tight
Posted on May 12, 2008
I have a admiral dryer and it quit working today had ahot wire smell and now it will not do anything bracker os good.
Sounds like the heating element may have burned out. I assume the drum still spins??
Jan 24, 2017 | Admiral Dryers
Tip
How to Replace Heating Element from a Maytag Dryer?
The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.
2) Locate the vent hose on the rear of the dryer and disconnect this hose from dryer unit.
3) The hose is mostly fixed in a metal clamp and the metal clamp is fixed by the screw. Loosen the screw and remove the clamp and remove the hose.
4) The heating element is located in the cabinet.
5) In some models the cabinet is located at the rear of the dryer. And in some model its located in the front of the dryer.
6) Locate the heating element cabinet and remove the screws holding the cabinet.
7) You will see the heating element now. There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.
8) Remove the connector carefully from heating element with the help of needle nose plier.
9) After the wires are removed from heating element’s terminals. Remove the screws holding the heating element.
10) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
11) Remove the old heating element and insert the new heating element.
12) Connect all the wires as it were connected before.
13) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
on Mar 20, 2010 | Dryers
Admiral Dryer, runs bu t does not heat
The thermostat, timer or the heating element itself are the places to check. Look at the circuit breaker for the dryer in the power panel. It will be two breakers connected together. If one trips but not both, the heating element will not heat but the dryer will run.
Nov 17, 2014 | Admiral Dryers
Why do i have no heat on my dryer after cord was replaced after it caught on fire?
I would check the heating element for continuity. If you don't have a multimeter, you could buy a cheap one or borrow one maybe? I found a video on youtube in case you need to know how to do it. Good luck
Aug 06, 2014 | Admiral Dryers
How do you get to the element on admiral dryer model ADE7005AYW
to start, you need to unplug the dryer, then remove the front panel and look at the rear left and you will see the element. remove the 2 connectors and 2 screws holding the element and to install your new one just reverse the procedure. be carefull not to touch the new heating element coils. your skin oils will shorten the life of the element. good luck to you.
Feb 05, 2011 | Admiral Washing Machines
Wont heat up
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
May 21, 2009 | Admiral AAV7000A
The black wire burnt off on the line going into the heating elem
No, you do not need to remove the drum. But you will need to remove the cover from the blower assembly. Using a volt meter, check the elements continuity to determine if it is bad or good.
Apr 16, 2009 | Whirlpool LER5636P Electric Dryer
Heating element
Might I suggest this site if you are a do it your self.
http://www.appliancerepair.net/dryer.htm
You have to raise the top take off the front and the tub should come out. Wala the heating element. Hope this helped, if not let us know.
Mar 16, 2009 | Dryers
I have a Kenmore Elite Model number 110.63022100 which isn't heating. I just cleaned the vent which was a problem. I assume this has caused a problem with the heating element or thermostat. What do I do...
Is the drum spinning, but not heating? Or...is the drum not spinning at all?
First, we'll assume your dryer is spinning, but just not heating. If your dryer vent was clogged as you stated, it is common for the thermal cut-out (TCO) to blow. This is a non-resettable device that acts as a fuse. Once it blows, it has to be replaced. There is also a possibility that the heating element went bad, if the TCO didn't do it's job. To check, you will have to remove the lower panel under the door. There are some screws under the bottom lip of the panel that you will have to remove and then the panel should just drop down and come off. CAUTION: Please UNPLUG the dryer BEFORE servicing anything inside. There are still dangerous voltages present with the dryer turned off.
Now located the heating element. It will be on the right-hand side encased in a heater box. There are two small components mounted to the heater box housing. The one closest to the front of the dryer is the high-limit thermostat. The one farthest to the back is the TCO. The two work in conjunction to help regulate the temperature inside the dryer, as well as, protect the heating element. Locate the two wires coming off the ceramic terminal of the heating element. Unplug these two wires and do a resistance check across the terminal. If the heating element is good, it will read about 9-13 ohms. Now remove the two wires from the TCO and perform a resistance check. The resistance should read 0 ohms (or a short) if good. If the TCO reads infinite (or open) it must be replaced. The same applies the the heating element. If the TCO requires replacement, it is strongly recommended by the manufacturer that you replace the high-limit thermostat at the same time. In many cases, the two components are sold as a set. The reason being that if the heating circuits overheat, there is a strong potential that the thermostat will be damaged as well. Replacing only one of the components can result in having the replace the other a short time later.
Now, if your dryer does not spin at all, you probably have a blown thermal FUSE. There is a difference between the thermal FUSE and the thermal CUT-OUT. The thermal fuse is located on the air blower housing right under the drum, and is a white plastic component. Remove the wires from it and perform a resistance check. It should also read a short if good. If not, it must be replaced.
If you need parts, here are the part numbers:
Thermal Cut-out/Thermostat Kit (part #2821)
Thermal Fuse (part #2923)
Heating Element (part #525502)
You can find all these parts at repairclinic.com, along with the price information & pictorial part index. Just type your model number in the search menu. I hope this helps you. If you need any further assistnace, please post back with comments and let me know.
Feb 06, 2008 | Dryers
Heating element
Disconnect the power.
Slide the Dryer away from the wall.
Pop up the top
You should see the heater in the back.
Remove the wires connections, and move them to the side
Remove the retianing screws
Pull the heater out.
Put the new heater in and reverse the procedure.
Oct 29, 2007 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
720 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
