Question about Dynex DX-EF101 (DXEF101) External Floppy Drive
DX-Hden10 I am trying to install the DX-HDEN 10 to Windows Vista but its not bring up the Add Hardware box...how do I install
  • GDB3 Jun 19, 2008
    Same with XPSP3. Cable Select seems to be the right dip switch setting, but drive does not appear. All USB stuff in Device Manager is ok. Grr...George Bigham
  • Anonymous May 20, 2009
    drive does not appear too....
Screen resolution
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Sep 10, 2012 | Computers & Internet
Tip
Install HP OfficeJet Pro K5400 color printer on Windows 10 64 bit.
I went around in circles for two hours trying diagnostic programs from HP that were supposed to install this printer. Instead they basically just bring up the Windows Add Printer dialog...but the printer was never available from the hundreds of HP printers in the dropdown list.
The solution is to run the Windows update form the Add printer dialog box to get additional printers options. This may take a half hour or more to run, but once it has, it will include the K5400 in the list. Once installed, it works fine with MS Office and Adobe Creative Cloud applications.
on Dec 20, 2015 | Office Equipment & Supplies
Need to reset the pasword on my del inspiron 1521 with vista
1. Reboot the Windows Vista
and boot up with Windows
Vista installation DVD.
Crack Windows Vista logon
account password in minute
with the Windows Vista
installation DVD. Click on the
Repair Your Computer
option, bring up Command
Prompt to open Local Users
and Groups management in
MMC.
2. While the Windows Vista
installation interface pops up,
click the Repair You
Computer link at the
bottom-left corner.
3. Next, the System
Recovery Options dialog box
appears. There are few
options that related to
repairing Windows Vista,
looks like Recovery Console
in Windows XP:
Startup Repair options is
used to automatically fix
problems that are
preventing Windows Vista
from starting.
System Restore to restore
Windows Vista setting to an
earlier point in time.
Windows Complete PC
Restore to restore Windows
Vista from a full system
backup.
Windows Memory
Diagnostic Tool could be the
first Microsoft memory
tester toolkit that bundled
with Windows setup media.
Command Prompt is the
target option of this Vista
hacking guide. Click on this
option now.
4. In the Vista Command
Prompt, type mmc.exe and
press ENTER key to bring up
the Microsoft Management
Console.
5. Click on the File menu,
select Add / Remove Snap-
in option, locate and select
the Local Users and Groups
on the left panel, and click
Add button to add it to the
right panel.
6. Now, the Choose Target
Machine dialog box pop up.
Keep the default setting by
clicking the Finish button -
that means using the Local
Users and Groups snap-in to
manage this local computer,
and not another computer in
network.
7. Click OK button and
return to MMC windows.
Under the Root Console in
left panel, double-click Local
Users and Group that was
added earlier. Click on User
folder, locate and right-click
the target Vista logon
account that found in the
right panel.
Select the Set Password
from the right-click menu to
set a new password / reset
old password.
***Note this does not work
on all versions of Vista***
In case if you dont have a
windows vista DVD then call
DELL and ask them for a
DVD. You need to provide
the details like Name, Phone
# and Address which you
provided when you
originally purchased the
system. In case you want
the DVD to be shipped to
alternate address, you can
provide after the
confirmation.
Dont forget 2 vote if u lik it.
Jul 25, 2011 | Dell Computers & Internet
How to enable ms fax services
  1. 1
    Open the Start menu and select "Run", then type "appwiz.cpl" into the textbox and press "Enter". This will bring up the "Add/Remove Hardware" dialog box.
  2. 2
    Click the "Add/Remove Windows Components" button in the left portion of the dialog box. It will take several seconds for the list of installed components to compile.
  3. 3
    Click the check box next to the "Fax Services" entry and click "OK". This will start the install process for the Windows XP Fax Service. You will be prompted to insert your Windows XP setup disk at some point in this process. Do so, then press "OK" to continue and complete the installation.
  4. 4
    Click "Finish" to exit the installer program.
Jan 14, 2011 | Dell 924 All-in-One InkJet Printer
Need driver for dynewx dx-ebusb for Windows 7
According to the dynex web site, this adapter is only compatible with Windows vista and earlier. There is no mention of compatibility with Windows 7 however you can try using the software install from the dynex website. Try running the install and if it does not start, try running it in Windows Vista SP 2 compatibility mode.
http://www.dynexproducts.com/products/computers/DX-EBUSB.html
Thanks,
Pat
Nov 08, 2010 | Dynex Wireless-G USB 2.0 Network Adapter
When I initiate the game " My kingdom for the princess" a dialog box appears " cannot init direct 3D ". I have the version installed dx 10 and already I have throw the diagnosis "dxdiag" and everything...
You likely need to update your drivers for your video card. surf to your video cards manufactures web site and download the latest and greatest software/drivers for your video card model. run, install , restart and try again. This will likely solve your directx issue. cheers
Aug 29, 2010 | Microsoft Windows Vista Ultimate Edition
Is there a way to run a Dynex DX-UC104 with vista.
Sounds like you need to make sure your chipset drivers are up to date and all service packs are installed.
Ther is no reason it will not work in vista as it works in windows 7 64bit.So visit your motherboard site to get bios updates and driver updates, then update all through windows update and try to reinstall.
Windows should install a driver for vista.
this is a link for non vista
http://www.dynexproducts.com/t-drivers.aspx
Jun 14, 2009 | Dynex DX-UC104 (DXUC104) Serial Adapter
Integrated webcam not working
try restarting or research for a compatible driver with your hardware and platform
May 21, 2009 | Dell Vostro 1510 Laptop
New comuter with windows vista and can not load printer hp photosmart 7660
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click the Windows icon, click Control Panel , click Hardware & Sounds , and then click Printers .
3. Click Add a printer .
4.Click Add a local printer .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select "Deskjet 5600"
9. In the Printer name text box, type the printer name, and then click Next . The printer driver starts to install.
10. After the computer displays a message that the printer was successfully added, connect the USB cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Now let's configure the driver
1. In the printer folder, right-click the name of the printer, and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to USB.
Now let's make a test
1.Click the General tab.
2. Click Print Test Page
Your printer should start printing in a few seconds.
Dec 02, 2008 | HP Office Equipment & Supplies
Drivers for windows vista
Windows Vista is pretty good with connecting to the web and scanning for it own vista drivers drivers compatible with your hardware automatically. Some things need to be manually done. Any specific piece of hardware your having trouble with?
Nov 24, 2007 | Micro Innovations IC100C Webcam
Dynex DX-EF101 (DXEF101) External Floppy Drive Logo
318 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
