Question about Whirlpool RF378 Electric Kitchen Range
How to reassemble the oven door
The other day i took the oven door apart to clean the grease streaks off of the inside. The problem is, there are two white plastic pieces that seem to go on the sides and I can't seem to get them to fit in anywhere. Please help
  • judyj4000 Aug 21, 2008
    To molding pieces on the sides should hold the glass in place.  However if the molding pieces are inserted into the holes at the base, the glass will not fit into the molding.  Help.
  • due mass Nov 01, 2008
    I have a Whirlpool oven. I also took it apart to clean the grease stains on the inside. I'm having trouble getting the two white moldings to fit in place along the side of the door. I already accidentally broke one trying to get it back in place & costs nearly $25 to replace.
Shock981, did you ever figure it out? I'm having the same problem.
Posted on Nov 21, 2010
How do i clean the inside the glass on my oven door
The door usually has about 4 to 8 screws on the inside. Remove the door first by opening it to 45' and lift it off its hinges. Sit it on top of the stove carefully after putting an old towel and a garbage bag on top of it. Remove the screws in the door and the inside will lift off the outside skin. Clean the glass with oven cleaner and reassemble. Ours needs doing too!
Feb 11, 2016 | Ovens
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
How do i clean between glass doors on bottom oven of fagor fb1982x4 ?
disassemble door , clean glass , reassemble. door.
Jul 27, 2014 | Fagor Ovens
OVEN GLASS INSTALLATION
MODEL #TES356TD SERIAL RWO0415338 ESTATE
Jan 17, 2014 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
THE GLASS ON MY OVEN DOOR IS STREAKED. CLEANER/CONDENSATION HAS GOTTEN UNDERNEATH GLASS. DRIVES ME CRAZY LOOKING STREAKED. ANY SUGGESTIONS? THANKS
usually there is some way to take either the handle off of the door, or take the door apart from the inside and you can seperate the parts of the door and remove the glass and clean it and replace everything back.
Jun 22, 2010 | GE Profile JTP18 Electric Single Oven
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
Grease in between glass on oven door
You have 2 pieces of glass that are separated by a frame then sealed. What has happened the seal has been broken and thus allowing air and grease inside. You can take it apart but the grease will come back, or you can buy a repalcement glass and be done with it. The question is, do you want to go to the trouble of cleaning the glass (1-2 hours of disassembly and assembly) probably once every 2 months depending on how often you use the oven, or buy a new one and it will always be clean. One caution, cleaning the glass periodically weakens and flexes the metal frame or band thus making it harder to properly seat the glass.
Feb 22, 2009 | Kenmore 47783 Electric Single Oven
Yellow Streak on Images
I took the scanner apart. Then using a dampened eyeglass cleaning cloth, I gently cleaned the 3 internal mirrors.
No more yellow streak! :)
May 27, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Whirlpool RF378 Electric Kitchen Range Logo
338 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
