Question about Kenwood KDW243A Builtin Dishwasher
Having probs with my dishwasher can u help - Kenwood KDW243A Builtin Dishwasher
  • a_proud Aug 07, 2010
    i have power 2 my machine but i can set to a program and it seems the door doesnt click into place do u have a solution
  • Kenwood Master
  • 43,501 Answers
Not sure exactly what your problems are, but I have a bunch of tips concerning dishwashers and their problems...
Check out this on and at the bottom there are links to others...
Dishwasherhaving probs with my dishwasher can u help - 2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 07, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Aug 08, 2010
    Yes... either the latch needs to be adjusted or the switch that senses when the door is closed has gone bad....my vote would be for the door switch... that is not hard to repalce and can be bought online easily...
    How to Buy Appliance Parts Online
    http://www.fixya.com/support/r3907570-bu...
    heatman101
I have an LGLD1415M dishwasher,that had a prob with water overflowing onto floor. i cleaned the filters and then turned the thing on, all the water left inside the washer was pumped out.but i still have...
E1 means: Water Level in Drum lowering, this would usually mean there is a leak on one of the pipes. But from previous experiences it is more than likely that it is the Circulation pump. It will have to be replaced, as it is a common spare that has to be replaced on L.G Dishwashers (lifetime 12 - 18 Months usually) - Not overly expensive. Usually is about 20%-25% the price of a new Dishwasher. The Circulation pump is fitted to the sump. Part Number: 5859DD9001A
See below a image of what a Circulation Pump looks like:
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Apr 08, 2011 | Dishwashers
Dishwasher not cleaning properly, think the prob is the bottom blade is a bit clogged but i am unable to see how take it out can you advise thank you
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 18, 2010 | Indesit 18 in. D41 Slim-Line Free-standing...
Unable to reset after LE problem.
LE is a Leak error, the leak sensor is on the very bottom of the machine. you can let it sit for a while till the water dries and it will start again. If it happens again then you'll have to call for service, that or pull out the unit yourself.. prob. not recomended.
Apr 01, 2010 | Samsung DMR57LFS Stainless Steel Builtin...
Water is not draining completely from the dishwasher. About 1-2 inches remain in the bottom. Seems to drain most of the water during the wash cycle, but a bit remains. Thoughts on how to fix this?
either the check valve on the end of the drain hose that connects to the drainpump motor is closed shut or sometin is clogged inside the drain hose..... also maybe you pump motor assmbly is faulty... u prob need wet/dryshop vac and drain it out from inside then check that hose... hope this helps... possibly may need to replace that drain hose,,, prob not worth reparing if its a pump motor depending on which brand some had 5 yr part warranties on the pump motor assembly
Jan 30, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
The detergent cup won't open.
common prob with dishwashers this just throw tab in bottom of washer and leave door open see if that helps sort it after a few washes
Aug 14, 2009 | Dishwashers
Detergent sticks in main wash compartment. We use cascade complete with bleach (hydroclean action). When this problem started, I switched to cascade complete (liquid) and still same thing happens. The...
Jsmarquez, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Jsmarquez), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 25, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
De 73 tripping house electrics
NEED TO REMOVE AND CHECK WIRING ESPE THE HEATING ELE AND MOTOR WIRES AND LOOK @THE HEATING ELE INSIDE THE ENCLOSURE CLOSE
Dec 12, 2008 | Indesit 24 in. DE73 Evolution...
DeLime light and detergents not flowing into dishwasher
Make sure the probs are clean inside of unit.Lime build up and calcium deposits may have occurred.
Nov 20, 2007 | Dishwashers
Dishwasher not running
just got this, and have same prob, i have run through all checks
Aug 26, 2006 | Miele Premier-Plus Built-in Dishwasher
Kenwood KDW243A Builtin Dishwasher Logo
246 people viewed this question
Top Kenwood Dishwashers Experts
Oloyede Monsuru
fadirahal
Level 1 Expert
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
