Question about Hyundai ImageQuest HQP421HR 42 in. HDTV-Ready Plasma Television
I HAVE A HYUNDAI PDP42V PLASMA TV MY ELECTRICS TRIPPED THE OTHER DAY AND WHEN I PUT THE ELECTRIC BACK ON MY TV WILL NOT EVEN TURN ON I HAVE TESTED FUSE AND THE ELECTRIC SOCKET WORKS?
commanderzod
  • 112 Answers
SOURCE: electrical problem with 2001 hyundai xg300
Check the wiring behind the headlight.
It sounds like you have a short somewhere.
A live wire is making contact with an earth somewhere.
Posted on Nov 05, 2008
ghost4548
  • 776 Answers
SOURCE: No power at socket for right break light for 2003 Hyundai Elantra
As you can see in this wiring diagram, power supplied is series/parallel
Posted on Jul 04, 2009
SOURCE: 2001 Hyundai elantra. Headlights, electric
check for any circuit brakers near the fuse box, if theres any of them reset them by introducing a paperclip in the small hole and press, you will hear a click.
Posted on Jul 20, 2009
  • 105 Answers
SOURCE: 2007 hyundai accent...a/c and blown fuse, electrical short
check hor wire going to compresser make sure no short to ground if compresser uesd a speed senser in compressr check it also
Posted on Mar 14, 2010
  • 4793 Answers
SOURCE: air bag lite on hyundai santa fe 2003
if you try to test the airbags and you short across the terminals it will take your head off.only check if you know exactly what you are doing.check the computer for any faults,then check power to sensors thats it.....
Posted on May 31, 2010
When plugged in its tripping my electrics,i changed the fuse it worked, when i tried to use it again it has tripped my electrics
have the electrics tested for earth leakage ( faulty lead insulation, pest infestation across points etc)
the tripping indicates a electrical problem and is tripping out before some one gets electrocuted.
May 19, 2015 | Washing Machines
My plasma tv won't turn back on after a power outage???
First, unplug the TV, wait 30 seconds to 1 minute, then plug back in & try it. This allows the unit to reset.
Be sure you AC outlet breaker has not tripped.
could also be the TV fuse or power supply PCB.
You should be sure to put a good surge protector in line with this TV as these constant surges are going to severely shorten the life of the unit.
Jul 24, 2014 | Televison & Video
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
Hello, I hope all is well: the cz-7007 is not working at all. I've had it less than 3 months. Thank you and have a blessed day. Best Regards, Dr. M.J George-McBride, PhD
Good day, Doctor.
First, have you tested the wall receptacle that the heater is plugged into? Have you plugged a lamp or other electric appliance into it, to see if it's working? If nothing else works in that receptacle check for a tripped circuit breaker in the panel box of your home.I f there is one tripped, make sure nothing is plugged into the offending receptacle and reset the breaker, by turning it on. If one is tripped, now you need to figure out what tripped it. Was it the heater? Probably so. In any event, plug the heater back into the receptacle and turn the heater on. Did it trip the circuit breaker again? If so, there is an electrical short in the heater. Since you have only had it for 3 months, I would assume it's still under warranty. If so, follow the instructions in the Owners Manual about returning it to the manufacturer for repair or replacement.
Hope this helped to solve your problem.
Feb 12, 2011 | Comfort Zone CZ7007 Oil Filled Electric...
I have a Weslo Cadence M5 treadmill. When i used it, it tended to trip out the electrics when the treadmill was started, but worked when I put the trip switch back up again and tried again. However, it has...
hi, firstly change the fuse in the plug to a higher voltage, then if you are using an extention wire make sure all the wire is unrolled. i had the same problem with my m5. i was using an extention wire on a roll that was shorting out the trip on the treadmill and cutting the electric off. so just by putting a higher amp in the plug and i am now using a 2m extention alot safer and much better,
Nov 18, 2010 | Cadence Weslo 5.0A Treadmill Walking Belt
My hyundai santa fey has just lost all electrics.Drove it fine to shop turned engine off. went to turn it back on nothing -no lights nothing from the battery even the key doesn`t work.tried jump start but...
i would start by checking the connections on the battery and having the battery tested, also why where you taking it to the shop?, if the connection are dirty a jump start wont work, they may look clean but loosen them and twist them on battery terminals to make good connection then tighten them ,and make sure battery is fully charged,
Jun 11, 2010 | 2006 Hyundai Santa Fe
Tried plugging something in :(flashing light.no pwr.
you have tripped the tv's safety power down feature, try unplugging the tv for 15 mins to an hour then try to turn it back on, if it still ceases to function, the tv will need servicing.
Oct 01, 2009 | Panasonic TH-50PX75U Plasma HDTV
Open Questions:
Hyundai 32" LCD displaying "invalid service "on some HD Staions Have just purchased a Hyundai 32" LCD Model CB-L3236LCD. Locallly I have Channel Prime HD and then Prime1, Prime2 and Prime3 which may or may not have differing programs to Prime HD ( I imagine in the future they will). Problem is on Prime 1,2,3 I either get a flash of the program then it returns to a blank screen with a blue box jumping all over the screen with "Invalid Service" written inside the box. Occassionally I may get a great reception on these stations but the Invalid Service box still appears. I can have a reception on Prime 1 say ( with Invalid Box0 and a blank screen on 2 and 3 with the invalid box. Very random it appears but common thread is the "Invalid Box". I only experience this with the Prime 1,2,3 Stations. I have a an older masthead amplifier booster system and I am about 5 kilometers line of sight from the Prime translator . I have a Panasonic 52" LCD as my main set which experiences no problems and have tried the Hyundai 32" on the aerial outlet which supplies the Panasonic in event the problem was due to a weaker signal at the Hyundai's normal location BUT I still have the Invalid Service problem with Prime 1,2,3. I went back to the store of purchase and tried their display set ( running on 'rabbit ears' aerial and less than one kilometre from the translator and the same problem existed on that set with Prie 1,2,3 only Anyone have any solution to this problem. Any software upgrades available for these models? Thanks in advance for any replies
Dec 19, 2008 | Hyundai ImageQuest HQP421HR 42 in....
Hyundai ImageQuest HQP421HR 42 in. HDTV-Ready Plasma Television Logo
43 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
