Question about Poulan Pro 22" Self Propelled High Wheel Mower
Where is the oil plug - Poulan Pro 22" Self Propelled High Wheel Mower
  • 100 Answers
If its not on side of engine it will be underneath but do not turn mower over wrong way.... disconnect plug lead first and turn mower over so that sparkplug points to sky...
Posted on Aug 14, 2010
2001 ford windstar oil leak from oil plug
There could be several causes for your leak:
  • Oil plug is loose
  • Oil plug is stripped and can't be tightened
There are some products that will substitute for a bad oil plug. Most repair shops will try to sell you a new oil pan. Sometimes a small gasket around the oil plug will stop the leak as well.
Oct 29, 2011 | 2001 Ford Windstar
Weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
Jun 13, 2011 | Mtd 22" Yard Machine Push Mower
Where is the motor oil drain plug on flxh
This is straight from the repair manual:
1. Ride vehicle until engine is at normal operating temperature.
2. Locate oil filler plug/dipstick on right side of vehicle at top
of transmission case. To remove the oil filler plug, pull
steadily while moving plug back and forth.
3. Locate oil drain plug at front left side of the oil pan.
Remove the oil drain plug and allow oil to drain completely.
4. Inspect the oil drain plug O-ring for cuts, tears or signs of
deterioration. Replace as necessary.
5. Remove the oil filter as follows:
a. Obtain the OIL FILTER WRENCH (HD-42311). The
tool allows easy removal of the oil filter without risk
of damage to the crankshaft position sensor or
cable.
b. Place the jaws of the wrench over the oil filter with
the tool oriented vertically. See Figure 1-1.
c. Using a 3/8 inch drive with a 4 inch extension, turn
wrench in a counterclockwise direction. Do not use
with air tools.
NOTE
Use OIL FILTER WRENCH (HD-44067) if HD-42311 is not
available.
6. Clean the oil filter mount flange of any old gasket material.
7. Lubricate gasket with clean engine oil and install
new
oil
filter on filter mount. Hand tighten oil filter 1/2-3/4 turn
after gasket first contacts filter mounting surface. Do
NOT
use OIL FILTER WRENCH for oil filter installation.
NOTE
Use of the Premium 10 micron synthetic media oil filter is
highly recommended, Part No. 63798-99 (Chrome) or 63731-
99 (Black).
8. Install engine oil drain plug and tighten to 14-21 ft-lbs
(19-28 Nm).
9. With vehicle resting on jiffy stand, add 3-1/2 quarts (3.3
liters) engine oil as specified in Table 1-1. Use the proper
grade of oil for the lowest temperature expected before
the next oil change.
Apr 05, 2011 | 2008 Harley Davidson FLHX Street Glide
I added oil to my Cadillac and it drained onto the ground
Before adding any more oil, make sure that you have securly replaced and tightened the oil drain plug (which is located on your engine's oil pan, under your car).
The FixYa Team!
Feb 01, 2011 | 1996 Cadillac DeVille
Were is the drain plug located on a 2007 chevy 5.3 on the passenger side of engine . is it behind the ac unit. i want to put a engine block heater in.
The block drain is on the passenger side of the engine, in the center of the block near where the oil pan attatches to the block.
Engine Block Plugs/Sensors
100 - Engine Block
100 - Engine Block
101 - Oil Gallery Plug - Front
110 - O-Ring
111 - Oil Gallery Plug - Rear
112 - Oil Gallery Plug - Side
113 - Washer
114 - Engine Coolant Heater
115 - Washer
116 - Oil Gallery Plug - Side
117 - Washer
130 - Transmission Housing Locating Pin
145 - Washer
146 - Engine Block Coolant Drain Hole Plug
701 - Crankshaft Position (CKP) Sensor
702 - O-Ring
718 - Knock Sensor
718 - Knock Sensor
739 - Bolt
739 - Bolt
750 - CKP Sensor Bolt
Oct 19, 2010 | Chevrolet Silverado 1500 Cars & Trucks
When changing spark plugs, I find oil in the thread area. Only one spark plug got this problem, the others are clean. No overheating, no smoking, no oil usage! Maybe valve stem seal is leaking? Vehicle: A3...
it could be that oil has got in to the port where the plug goes when topping the oil up, hence goes on the tread when removing the plug try wiping the hole with the plug out or look down each to c if there is oil in that area, if the oil looks "burnt on th plug" you may have a crack in the head where the plug goes, if you are buning oil it would make the tip of the plug a different colour to the rest,
Dec 05, 2009 | Audi A3 Cars & Trucks
Change oil filter honda civic 2003
buy new oil filter, oil, and a new drain plug and gasket. the used plug is prone to leakage. remove drain plug and drain in a big enough pan for all the oil. oil filter is located on rear of engine. easier to remove from the bottom of the car. put oil on the seal of the new filter and hand tighten. replace oil plug with new gasket and plug and tighten to 33 foot pound. add oil that is required and start car. when oil light goes out shut car off and check oil add oil as needed.
Oct 12, 2009 | 2003 Honda Civic
Number 4 cylinder miss fire
Check your distributor cap & wires first. If all is ok pull the spark plug and check if it's oil fouled. If there is no oil on the plug the plug might be bad. if there is oil on the plug you can get an adaptor that screws over the end of the plug and shields it from getting oil fouled. Of course this is a temporary solution for a piston ring or valve seal problem. I had a caddy I ran with plug shields fo 5 years so they work! Good luck!....PS If your plug is oil fouled you can also use a heavier oil like a 20/50 or use 4 quarts of 10/40 and a quart of lucas oil stabilizer. This will help keep the oil where it belongs and don't forget to do an oil change every 2,500 to 3000 miles.
Sep 23, 2009 | 1997 Chevrolet Blazer
Where do i put the differential gear oil
  1. Before changing or inspecting oil, be sure to stop engine and lift vehicle horizontally.
  2. With vehicle lifted up, check leakage. If leakage exists, correct it. NOTE: Whenever vehicle is hoisted for any other service work than oil change, also be sure to check for oil leakage.
  3. Remove oil filler plug (2).
  4. Remove drain plug (1), and drain old oil.
  5. Apply sealant to thread of drain plug (1), and tighten it to specified torque.Tightening torque Differential oil drain plug a: 23 Nm (2.3 kg-m, 17.0 ft. lbs.)
  6. Pour new specified oil until oil level reaches bottom of oil filler plug hole (3) as shown in figure. NOTE:
    • Hypoid gear oil must be used for differential.
    • It is highly recommended to use API GL-5 80W-90 gear oil.
Differential oil specification: API GL-5 (For SAE classification, refer to viscosity chart [A] in figure.)
Differential oil capacity (Reference): 0.9 - 1.1 liters (1.9/1.6 - 2.3/1.9 US/Imp. pt.)
  1. Apply sealant to thread of level / filler plug, and then tighten it to specified torque. A: Sealant 99000-31260SUZUKI Bond No.1217G Tightening torque Differential oil level / filler plug b: 23 Nm (2.3 kg-m, 17.0 ft. lbs.)
Jun 04, 2009 | 2007 Suzuki Grand Vitara 4WD
Poulan Pro 22" Self Propelled High Wheel Mower Logo
56 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
