The display show dE after a few minutes run - Washing Machines
  • 3,051 Answers
Hello there:
dE - Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board Replace any parts that have failed any of these checks I.E lid switch ect .ect
Posted on Aug 07, 2010
I KEEP GETTING A DE MESSAGE AFTER A FEW MINUTES
My washing machine is displaying an error code ... - Samsung
www.samsung.com/my/support/skp/faq/1033803
Samsung ElectronicsFeb 19, 2014 - ... your Samsung washing machine and the solution needed to resolve the .... If problem persists please call Customer Careline. *. dE. dE1. Ed.
Aug 06, 2015 | Washing Machines
Tip
Display showing p2
turn unit on by display , runs for a few minutes and shout it self off , blinking p2
on Sep 25, 2008 | Mitsubishi PK18FK/FL Air Conditioner
Picture disapears after few minutes
I think the electronics inside it have failed. My guess is that because its the picture only, it will fail in the same way if you play dvd into it for the same amount of time. The failure happens after it has warmed up, if you take it out into the cold you may get 1 minute more before it fails.
It needs replacing, its not cost effective to repair something like this, the failed parts may have partially damaged other parts in the unit so they could fail after a repair.
Dec 19, 2013 | Televison & Video
Indicator light
May be showing a fault code, you need to count how many times it flashes. Could also be a delay or de ice mode which will go away after a few minutes
Aug 05, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
The gps automatically shuts off after few minutes
When you turn the unit on and get to the screen showing Where To?, View Map and Travel Kit look on the upper right hand corner of the display and make sure you see the battery icon all green. If it is not then the battery is not charged
Apr 04, 2010 | Garmin Nuvi 660 GPS Receiver
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
F/02
DURéE EXCESSIVE DE LA VIDANGE
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Monkey place minigame
for de hoop hold it in de air nd hopfully dey will jump through it
for de table make dem stand/sit on it for around a minute den call dem down
for de polls make dem run beside all of dem it might take a few trys
for de long table make dem also stand on it for a few seconds den move 2 de middle nd den de end den off nd hopfully it will work
hope it works it works 4 me :)
Aug 05, 2009 | Ubi Soft Catz 5 (Windows) (680901) for PC
My washer will not go through a complete cycle. It flashes F2 and will sit on SUD for ever as well as run on the last 1 minute for an hour. Help
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed. Si la durée de l’opération de vidange est de plus de huit minutes, le système commande la fermeture des électrovannes et l’affichage du code “F/02” clignote. Appuyer deux fois sur la touche PAUSE/CANCEL pour commander l’effacement. NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus tard le code “F/02” sera affiché. Possible Causes / Procedure 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Jun 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kemore he3 dryer error code E1
Hey fookie you need a thermistor for that dryer. It runs with no heat ?..Let me get a pic for you it is about 25 bucks oh and is part 42 on the pic below
Oct 23, 2008 | Dryers
Error code de
hi, i've got the same problem. But when i leave it for a minute or two with the beeping, it will automaticaly start its washing program. Without opening and closing the door. We probelbley need a new door sensor. I've seen them on the internet for $100. But as long it's washing like it does now. I'am leaving it like it is.
Aug 21, 2008 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
