Question about Ricoh Aficio 1035 Copier
How to connect the machin to the computer - Ricoh Aficio 1035 Copier
  • Andy Bell
    Andy Bell Aug 09, 2010
    first you need the printer drivers..if you go to Ricoh.co .uk and select support tab then driver network tab on right hand side this will take you to the driver site select you copier and down load the file to a folder on your desktop.. go to printers on your desktop and add printer when it ask for the driver select have disk and direct ot folder on desktop. install this and then connect copier either by usb or network cable turn machine on and your computer will find it .. make sure when you install you dedicate the port to either usb or network as the default is parrellel connection.
  • 67 Answers
Give it an ip address in the same range of your network
Posted on Aug 26, 2010
Testimonial: "computer can not detect xerox machine"
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
MFC_5840CN Will not print, not showing
Typically, a Brother machine stops printing, because the connection between the computer and the Brother machine is lost. There are multiple reasons for a lost connection.
  1. The Brother print driver is Offline.
  2. The Brother printer driver is not set as the default printer driver.
  3. The computer, not the monitor, connected to the Brother machine is set to go into sleep or standby mode. When the computer goes into sleep or standby mode, the connection between the computer and the Brother machine is lost and needs to be re-established.
Follow the steps below in order to re-establish the connection between the Brother machine and the computer:
  1. Verify that the Brother machine is connected with a USB cable and is not on a network.
  2. Verify the power cord and USB cable are securely connected. If the USB cable is loose on either end, disconnect and reconnect the cable securely. Test the machine by trying to print. If the machine does not print, go to STEP3.
  3. Cycle the power of the Brother machine by unplugging the power cord from power outlet, wait approximately one minute and plug back in. Once the Brother machine displays the date and time after plugging it back in, test the machine by trying to print. If the machine does not print, to Step 4.
  4. Reboot the computer connect to the Brother machine and then try to print again.
Apr 01, 2008 | Office Equipment & Supplies
Minotla di470
does your computer have the XP operating system??????
Very Legacy Machine, xp at best. as for connection if you do have xp locate the ethernet connection at the rear left side of machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 13, 2014 | Konica Minolta bizhub Office Equipment &...
Cannot recieve faxes more than 2 pages long. Message Communications error 232
The device has a communication malfunction.
possible diagnostics to be performed
1. The communication lines or phone connectivities are malfunct, consider unplugging each modem properly reconnecting taking keen observation of jack areas on the fax machine, and the external areas on the router units splitting the signals.
2. The fax machine paper feed system is clogged possible inspection of the tray areas making sure to unclog stuck paper.
a. The fax machines provides an image measurable in laser signals required to produce results immediately. Any delay in the signals or data when arrives in fax machine could cause incomplete imprint
3. The fax machine could have many messages queue causing delay malfunctions.
a. The type of signal splitter available at the location could cause to delay, where a delay excapes signal recognition on the paper only producing a few data records
important notes
1. consider acquiring a fax consigment at a time
2. consider distributing fax loads to another infrustruction
Error 232 is a connectivity message
1. possibly caused by accidentally unplugging a connection and reconnecting while fax machine was powered on.
2. possibly caused by connecting another fax machine to the set up of infrusture without performing system restore to intergrate all devices connected to the network.
3.possibly also caused by a computer program malfunction.
a. consider reinstalling the programs that connect the fax machine; for example access the computer networking infrusture icons located in the control panel area of the computer programs list bar to perform networking diagnostics for the fax machine
instruction s of performing a fax network reinstallation
1.The networks on the computer housing every additional peripheral device like faxes all share with printers, game consules and several recognisable within the computer server or mainframe computer. A wireless connectivy of several connection compromised the intergrity of some devices.
The response to the problem in computer sending a message with a number to make possible locating the by expert technictians.
2. Several peripherals connected to the computer server produces error messages readable where huge numbers being sysbols of easy problems only on a computer performing several resposnibilties, in which sitaution of faxes, the error 232 could be the number of faxe assigments failures, or number faxes waiting to be completed.
Dec 02, 2010 | Office Equipment & Supplies
I cannot connect to my Bizhub 250's web page on one specific computer in my office.
if you cannot connect to your bizhub 250's page then please perform these actions to get rid of this problem.
steps are as follows:- 1-Check that your computer is connected with the machine via network cable. (via Hub etc) 2-if you know the IP adddress of the machine then ping it from your computer. 3-To ping an ip address simple go to "RUN" at the start menu. and type "ping _._._._._,_,_, (ip address of the machine" in the blank you will type the ip address which you want to ping. after entering press "ENTER" if it shows TTL=64, or TTL=32, OK then it means your machine and computer ids coonected with each other. 4-is still webpage is not viewing then install the page scope software or check your connection between machine and computer.
Jun 19, 2010 | Konica Minolta bizhub C250 All-In-One...
Set Date
Entering the Date and Time Note: When your machine is connected to a computer with the MP driver installed, even if the date and time are entered from the Operation Panel of the machine, the date and time will be read from your computer every time you start the computer, turn the machine on, or disconnect and connect the USB cable. When using your machine connecting to your computer, set the date and time on your computer precisely.
The date and time will be reset when you disconnect the power cord or there is a power failure. In this case, you can set it again on the machine. Alternatively, it can be read from your computer and set on the machine by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ left ] or [ right ] to select <USER SETTINGS>.
3. Press [OK] two times.
4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
5. Press [OK].
6. Press [Stop/Reset].
Sep 13, 2009 | Canon PIXMA MP530 All-In-One InkJet...
How do I use the fax without going thru my computer just as a fax
Issue: How do I connect a telephone, answering machine or computer modem to my machine?
Solution: Connecting the telephone line and external devices to the MX310
Preparing the Machine for Faxing title-bar.gif Typical examples of connecting the machine are described below. The machine cannot send/receive faxes if the connection is incorrect. Connect the machine correctly.
i_important.gif Important
If the Power Disconnects Unexpectedly
If there is a power failure or if you accidentally disconnect the power cord, the date/time settings as well as all documents stored in memory will be lost. User data and speed dialing settings are retained. If the power disconnects, the following will apply:
bullet_s.gif You will not be able to send or receive faxes or make copies.
bullet_s.gif If a telephone is connected to the machine, you can receive voice calls.
bullet_s.gif Whether you are able to make voice calls depends on the type of your telephone.
sikaku.gif Methods of Connecting External Devices bullet.gif Connecting to an Analog Line t_01522.jpg
(A) Telephone line (analog)
(A) Telephone or Answering machine
Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A) . The machine may not operate properly.
bullet.gif Connecting a Telephone or Answering Machine via a Computer t_01724.jpg
(A) Computer
(B) Telephone or Answering machine
sikaku.gif Methods of Connecting the Various Lines The following are some basic connection schemes that apply when you are connecting to a non-analog telephone line. These are examples and are not guaranteed to suit every connecting conditions. For details, refer to the instruction manual supplied with the network device (control devices such as an xDSL modem, terminal adapter, or dial-up router) you are connecting to this machine.
(A) Digital Subscriber Line
(B) Splitter
(C) xDSL modem (splitter may be built-in to the modem)
(D) Computer
bullet.gif Connecting to an ISDN Line For details on ISDN connection and settings, see the manuals supplied with your terminal adapter or dial-up router.
Please be informed that you can access Canon's online support site for your printer by clicking here. You can find many solutions to your problems by searching their database once you have navigated to the support page for your model.
I hope this information allows you to resolve this issue. If not, reply back with a comment to this thread.
If so, please take just a moment to rate this post. Thanks!
Apr 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Win xp sharing connecion
For Windows XP Professional, the maximum number of other computers that are permitted to simultaneously connect over the network is ten. This limit includes all transports and resource sharing protocols combined. For Windows XP Home Edition, the maximum number of other computers that are permitted to simultaneously connect over the network is five. This limit is the number of simultaneous sessions from other computers the system is permitted to host. This limit does not apply to the use of administrative tools that attach from a remote computer.
Feb 01, 2009 | Microsoft Windows XP Professional With...
Connecting to a computer
Are you asking how to connect the Brother PE-400D sewing machine?  You have "how to connect the '4000D' to a computer and what risk if any".  Which machine are you asking about - these are two different sewing machines.  If you are inquiring about the Brother PE 400-D, then your answer is... this machine is NOT capable of being connected to a computer.  However, if you wish to purchase or download embroidery designs from the internet, you may look into purchasing the Brother PE Basic. This allows you to download embroidery designs from the internet to your computer hard drive and then load them on to a Brother memory card.  The Brother memory card can then be slipped into the proper slot for the memory card on the sewing machine.  You will need to purchase embroider designs that are in the PES format for you Brother machine to read it.  Hope this helps!
Oct 31, 2007 | Brother Disney PE-400D Computerized Sewing...
Fax installation
There is no installation CD for this machine. The machine sends, receives and copies. The machine will not connect to a computer and does not need a CD to perform it's functions. Years ago Brother had a 770 which is the father of 775 that connected to a computer by purchasing software and a cable(PCI-1). This software is outdated and does not work well with any of the current windows programs. Most Brother ink-jet and laser products will connect to a computer via an installation CD or down loading the drivers from Brother.com. None of their thermal machines will connect to a computer.
Sep 20, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Ricoh Aficio 1035 Copier Logo
44 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
