Question about Sony CMT-NEZ50 Shelf System
The system does not tourn on anymore. the red led is on, but you cannot hear the noise of the tape, tipical when the system was plugged to the power. I guess in this system there is not any fuse, so can you help me? thank you
Charging system troubleshooting
To begin in wall/ext outlet... use Voltmeter tester set it in AC volt if u don't have tester use other appliances plug in to check if its working. Next smell charger if there is a burn component inside there is strong smell "don't use it anymore" . 3rd Plug your charger and check if the unit is charging ...all unit/equipments that use charging system has a icon showing its charging those w/out screen usually red LED is ON if charging system is working. This are the simplest way troubleshooting charging system, I hope it will help
May 17, 2018 | Cars & Trucks
Where can I get a replacement plug that this cord will plug in to for my led lighted qillow tree
M12S 2 Pin Waterproof LCDs Led Power Supply Connector Replacement Black
44cm Length 2 Pin Waterproof Extension Connector Cable for LED Strips
get a 12 volt 5 watt power supply and cut the wires and connect red to the red or white stripe and black to the other,plug in to make sure it works if it doesnt,switch wires,then tape each connection with black tape
May 25, 2015 | Computers & Internet
My Acer 5552G won't turn on.
try a system reset see below link
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Jan 20, 2013 | Acer Aspire 5552 5552g 5553 5553g 5560...
To reduce background noise from an audio mixer
when you say background noise I assume you mean the inherant noise that electronics produce. the the first thing to do is to make sure that all you input connections are shielded type, you don't need to spend money on gold plated connections, but do buy cables that are made with stranded wire and of decent size, bigger (fatter) is better when it comes to minimizing high frequency losses. Next, calibrate your inputs one at a time with a 1000hz signal that is 0db inn level. You can find this signal online through a search. you can also buy small plug in devices that produce this signal at 0 db (that is Zero Decibles) this is a common reference for "consumer" grade mixers, If you can't or don't want to spend any money on this you can use a signal from any tone generator, and some mixers have them built it. If you don't have any of the former, here is what you can do. turn all you mixer controls to 0 (zero) detent. in other words, flat, no treble, no bass, no midrange. on your inputs there should be input level knobs, these woule be set to thier lowest positionn if using a line input signal. if a microphone that level would be different, but wait on that for a bit. now have all you input knobs (or sliders) at minimum level. Now turn on your amplifer (if your using one) or what ever you monitor the output with. Headphones is a good choice as you can hear everything.
You should hear nothing. (nothing is supposed to in the inputs yet) if you hear noise take note of what it sounds like. turn the sound output level out (if headphones, turn up to a high level) and listen again. is the noise white (hiss) or hum (low freqency) if you have no noise, you have a good mixer and that is what it should be.
No plug in your first input, this is your choice but I would suggest you plug in microphone, now turn it up to the point where you can hear your own voice, you should hear just that, and maybe anything in the backgroud (furnace, tv, etc_) the quieter your environment, the better you can adjust this. Remember you will now need to turn up the input level. If you have meters you should be able to adjust the input to register in the green without turning red, a litlle yellow once in awhle is ok.
If this is quiet and clean you are ready to move on. turn that mic down to zero, but leave the input where you set it.
now plug in a line level source (your tape player,/cd player/ but don't use your computer as a source (yet). without anything playing on your machines you should hear very little noise in your headphones, if you hear a lot of noise you have bad cables.
Now play something through the tape/cd player, what ever and turn up the slider (not the input) this should give you a level,again in the green, with a little yellow, NO RED
once finished with this turn it back down and go to the next input. this time plug in your computer which most likely is coming from the green jack on the back (or front) of your PC/Mac or whatever. computers are very noisy machines, and just being close to one is sometimes enough to cause noise in a high gain system. anyway, plug in your computer and listen, you should hear some noise and I'd be surprized if this wasn't the source of your problem. make sure your volume level on the output of your pc is set to maximum, this will give you an advantage when recording. now turn up the slider on this input and listen for the noise level. good cables are important here and also the price of your computer may be reflected here as well since more expensive machines are better filtered and therefor produce less noise.
play a sound file (windows audio samples are noiseless and clearn) so use them if you can find thiem, look in your music folder for the sample files
You may hear some noise but your mixer is now set up at optimum and should give you nice sound if it is a quality mixer, good luck, Keith
Mar 24, 2011 | Audio Players & Recorders
Lg 50 in clicks but won't stay on.
Ur power board need it replaced,LED indicator light not sustaning power.
Jan 05, 2010 | LG 50PC1DR 50 in. Plasma HDTV
Screen of my ps3 went black, i cant see the menu
While the PS3 is off (red led)
Hold down the power button until you hear the second beep, quickly release.
That's it!
May 13, 2009 | Sony PlayStation® 3 (80GB) Console
Kyocera fs-920 static red light
Your more than likely out of ink.
Apr 16, 2009 | Kyocera FS-920 Laser Printer
Tv don't come on
red light flashing can hear clicking noise but wont turn on
Sep 08, 2008 | Televison & Video
Labeling system trouble-shooting
This is a duplicate post, click on the following like for the original: http://www.fixya.com/support/t133614-labeling_system_trouble_shooting
Feb 10, 2007 | Brother PT-65 Personal P-Touch Electronic...
Sony CMT-NEZ50 Shelf System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
