Question about Kenmore 24642 Top Load Washer
The machine suddenly stop working right after finishing water had filled (the next action should start its washing cycle). Then there is no response, just as electricity is disconnected from it. Thank you for help.
  • Kenmore Master
  • 2,699 Answers
Try opening the lid a couple of inches and close it down a few times,do you hear a clicking sound?if not the lid switch is bad.on the right side of the lid you should see a piece of plastic connected to the lid that fits into a hole in the top of the washer,this hits the lid switch,stick a pen or something in the hole and see if the washer works,send the model number and i'll tell you what switch you have on your washer,the model number is on the back wall of the opening where you put the clothes into the washer or to the left of the lid switch.if your lid opens strait up and backwards the number is directly under the lid when it's in the open position
Posted on Aug 07, 2010
My washing machine wont fill up with water, what would the problem be, ive cleaned the hose at both ends so its not blocked?
usually the hot and cold water solenoid fail stopping water to flow
replaceable part
location
in where the hoses attach to the washing machine
May 09, 2016 | Washing Machines
My Maytag Performa washing machine will not stop filling with water and start the next cycle
you need to unplug it from the power when it does that to see if it stops filling. That will tell you if it is a valve issue or a problem with the controller
Feb 09, 2013 | Washing Machines
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
    My bet is that your cold water screen is plugged...
    If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Aug 31, 2010 | Frigidaire Washing Machines
    Agitator starts at begining of cycle before washer is full
    Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
    Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
    After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
    Quentin
    Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
    Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
    water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
    Apr 26, 2009 | Washing Machines
    Bleach dispenser
    This compartment works on syphon action caused by the water when filling, rmove syphon cover on dispenser bos or try pooring boiling water into compartment, this will usually resolve
    Dec 09, 2007 | Maytag Neptune MAH5500B Front Load Washer
    Kenmore 24642 Top Load Washer Logo
    49 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
