Question about IBM ThinkPad R40 2897 Notebook
I bought a used IBM R40 whose hard drive failed. I tried installing someone else's XP Pro on my computer and then trying to use my license key from the bottom of my machine. It didn't work. I get the now valid message. It is a 2722-27U model.
    Problem Solver:
  • 12 Answers
Must use an OEM install copy of the version on your key sticker. retail and upgrade versions will not work. i had the same problem with my r40. had to use e-donkey file sharing program to find it.
Posted on Dec 23, 2010
I bought a used ibm r40, changed the hard dsrive and tryed to load xp pro. after loading the system files the computer wants to reboot to finalise. After this it goes right back to fresh install start.
When you say you tried to load XP Pro, did the hard drive already have XP installed or are you installing it fresh from a CD? If you are installing it fresh from the CD and it is asking you to reboot, it seems as if you are letting it try to boot again from the CD. When it reboots and says "Press any key to boot from CD..." don't press anything, just let it boot. It should finalize the installation there!
Hope that helps!
May 23, 2011 | IBM ThinkPad R40 2722 Notebook
I need to find license and key for Rapid Restore, I upgraded my hard drive and now when I try to go to Rapid Restore it is asking for license and key. I have a Thinkpad R40 and Rapid Restore has Windows XP...
Rapid Recovery or Rapid Restore? Email the company that makes the program and ask them to send you your license and key. I can't find a program called Rapid Restore or I'd help you further. Rapid Recovery is made by Quest.
Oct 30, 2017 | Xpoint Technologies Rapid Restore PC...
Bought a ibm r40 at a auction but has no operating system
Get into setup(probably F2 at start up) and check what hard drive it has, if any.Then, does it have a floppy drive,or a CD drive? Also, if it has a hard drive, it is possible to connect to another computer and format, and install windows. Good luck.
Feb 21, 2010 | IBM ThinkPad R40 2897 Notebook
IBM R40 SoundMAX Dirver not found error
http://www-307.ibm.com/pc/support/site.wss/MIGR-61604.html
here is the sound driver you need...but remember that the problem might be from another point..anyway the silly stuff with sp3 and sp2 doesnt matter ...cause the sound driver its the same for all XP operating system ...sometimes its the same for vista too ...only in special cases need another ..
so ..download ...and after you remove from the system all the other drivers...( look into add remove programs from control panel ) I mean all other tries and any unfit drivers that ya might tried..restart ..run this one ...and it willwork ...
Oct 01, 2009 | IBM ThinkPad R40 2681
Not loosing data
No problem at all. Go ahead.
Do rate this fixya!
Jun 01, 2009 | Microsoft Windows XP Professional With...
Downgrade from Vista to WinXP Pro
No, you need to go into your computer's BIOS and set the ahcp mode to IDE. Then windows xp will see it just fine.
Please take a moment to rate as fixya. Thanks!
Feb 06, 2009 | Acer Extensa 4620 Notebook
Problem with some keys of keyboard
1. Sourcing a keyboard is easy, check EBay. Fitting it is easy, two or three screws from underneath and a single connector takes care of that. I just did one, and the keyboard cost me 20 pounds.
2. If you don't use the CD / dvd drive, then consider purchasing / loaning an external cd / dvd drive, which you then connect via USB. You can then reload Windows from this new device, and it will serve any new computers you may have in the future. Expect to pay 20 to 30 pounds from any high-street retailer.
To boot from this device (which you would want to do in order to load Windows from it), you will need to access the BIOS, and change the 'boot order'. So you interrupt normal boot, by pressing F1 (could be different o your comp), and make the USB cd / dvd the first device in the boot list.
Good luck.
May 16, 2008 | IBM ThinkPad R40 2722 Notebook
30 day use Windows Xp Pro
The problem is with the actual key that you are using. Not your computer, or the components inside of it. If you are certain that you are using a valid key Its likely that you have a a key for windows home, and you are trying to install windows professional, or visa versa... Either way, If all else fails, you could replace the OS ( Buy or download) much easier than the hardware inside your computer.
Basically your computer is fine, just get a valid OS. If your adventurous try ubuntu.
Hope this helps!
Jan 10, 2008 | Microsoft Windows XP Professional for PC
Reinstalling windows xp on a new hard drive - Thinkpad t30
If you can get your hands on a Windows XP cd, it will partition and format the drive for you allowing you to install from scratch. You would then just plug in the license key from the sticker on your laptop. As far as the recovery disk on the original CD, there might be an option on bootup that would have you push an F key to access it. Or you can usually order them online. It's not too hard to get the drivers you need from online so I would just go with any XP disk you can get your hands on. You'll be using your own license so you can even borrow one.
Dec 21, 2006 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad R40 2897 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
