Question about Dell (E210882) Motherboard
CHILL WILL'S (motherboard E210882) WOES!!!
I PURCHASED A DELL DIMENSION 4600 AROUND 1993-1995 ( E210882 motherboard ). SINCE THEN I ATTEMPTED TO UPGRADE THE RAM MEMORY TO 4-GIGABYTES USING FOUR STIX OF 1GB RAM (KINGSTON-TECHNOLOGY KVR KVR-400/ 1GR )( 74061708954 2.6V )( B EPE16B0764 ) (P850085-01253530 ).
WHENEVER I START UP THE COMPUTER STILL MOVES VERY SLOWLY AND SO I TRIED DEFRAGGING WHICH DIDN'T HELP. THEN I TRIED POWERING DOWN COMPUTER, RESTARTING AND PRESSING F2 KEY TO CHECK MY SYSTEMS CONFIGURATION AND FIND ITS RUNNING ONLY 4096MB DDR SDRAM INSTALLED MEMORY, RUNNING 333MHZ SYSTEM MEMORY SPEED, DUAL SYSTEM CHANNEL MEMORY MODE, 256MB RAM AGP APERATURE.
MY CPU SPEED COMPATIBLE, BUS SPEED 533MHZ, PROCESSOR 0 ID F29, CLOCK SEED 2.66GHZ, CACHE SIZE 512KB.
INTEL PENTIUM 4 PROCESSOR: 2.66GHZ LEVEL 2 CACHE: 512 KB INTEGRATED
BIOS VERSION: A03 SERVICE TAG: 36Q4B31
SINCERELY,
MR. C.C. WILLIAMS
PS.
I WOULD GREATLY APPRECIATE IF YOU COULD HELP TO SOLVE MY PROBLEMS WITH MY SYSTEM. (404) 840-8387
    Scholar:
  • 103 Answers
It seems like you have done everything right but im not 100% sure that your memory is correct. read through the description here carefully and you will see that this memory comes in two different packages. One of them is the 400 (the ones you bought) and another in the 333 flavor. I am hoping they did not make a mistake and gave you the wrong ones. Look directly at the memory and make sure. I am also including the system manual for your computer. Hope this helps.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/index.htm
Kingston's ValueRAM KVR400/1GR is a 128M x 64-bit (1GB) DDR400 CL3 SDRAM (Synchronous DRAM) memory module. The components on the module include sixteen 64M x 8-bit (16M x 8-bit x 4 Bank) DDR333 SDRAM in TSOP packages. This 184-pin DIMM uses gold contact fingers and requires +2.6V. The product is shipped in retail packaging and includes installation instructions.
Posted on Apr 27, 2008
May i ask, where ican find the motherboard driver E210882 model?
E210882 is not a dell part number thats the UL Labs Registration.
Sounds like a dimension 3000 motherboard 0TC667
http://support.dell.com/support/edocs/systems/dim3000/en/SM/index.htm
Oct 06, 2010 | Dell (E210882) Motherboard
Good day I want to use a sata hard disk and
you will need to put in your windows disc and press f8 or whatever you need to press to gain access to your bios settings once in set your pc to boot from cd not h/d it will begin set up for a new install and ask if you want to install a third party sata disk etc click yes at this and follow prompts, restart pc and change bios settings back to h/d detection should then work.
May 09, 2010 | Dell (E210882) Motherboard
Need drivers for Dell E210882
I think this motherboard is suppose to be for a Dell Dimension 8250.
You can download drivers from Dell. The direct link for this Dimension is:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=555&l=en&s=biz&ServiceTag=&SystemID=DIM_PNT_P4_8250&os=WW1&osl=en&catid=&impid=
Mar 30, 2010 | Dell (E210882) Motherboard
I have a dell dimension 4600 what kind of motherboard do i have.
Your Dell Dimension 4600 comes with an Intel motherboard with the Intel 865PE or 865G chipset running an Intel P4 class processor.
Here are the specifications for your machine and motherboard:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
Mar 07, 2010 | Dell Dimension 4600 PC Desktop
I have a Dell Dimension 4600 computer with a E210882 motherboard. I cannot find the driver cd that my aunt purchased with the computer. It is running a P4 2.66 cpu with a gig of ram. I just reformatted...
Here is the site you can get the driver from at dell:
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=5&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=DIM_P4_4600&hidos=WW1&hidlang=en&TabIndex=
Download the driver to another computer and then port it to your laptop using a thumb drive. Install it per instructions and go back to dell for the other drivers. There is also software available to detect all devices on your computer and find the latest drivers for those devices. It is called Driver Detective see the link:
http://www.drivershq.com/
Good Luck
Feb 01, 2010 | Dell (E210882) Motherboard
Does the E210882 MB have a sata port? Dell Dimension 3000 pentium 4, 3 G
No it doesn't. It has 2 IDE connectors.
Refer to: Dimension 3000 Specs
Thanks for using Fixya.
Nov 28, 2009 | Dell (E210882) Motherboard
Dell Dimension 4600 Cpu Fan replacement help
I know that there are many of these types of system boards out there, What I would do is contact Tiger Direct either in Canada at www.tigerdirect.ca or in the US at www.tigerdirect.com and send the sales team an email sales@tiger.com - They will usually find anything that you need and have very quick and reasonable shipping rates.
Give that a try and see if it works for you.
May 26, 2009 | Dell Dimension 4600 PC Desktop
Cannot load operationing system because of fault saying, "no hard disk found in this computer"
Check the data cable. Make sure it is fully connected. (Sometimes they come loose). Check all connected data cable's & power cables within the system. Start with the new drive you installed. Unplug the data cable & re-connect. Follow it to the motherboard & do the same. If no cable seemed loose than replace the hard disk drive's cable with a new cable. Standard 80-conductor Ultra DMA IDE/ATA interface cable. See below;
ab2779a.jpg When you start up the dimension 4600, enter the bios, watch your screen at start up. You will need to press F2 or F10 key to enter the bios.
Once in the bios check that you hard disk drive is shown.
Most bios will list the drive by its model number. If you see the model number of the drive chances are you can save & exit the bios. Button up the case. You should be able to load windows.
Luck!
Mike
May 05, 2009 | Dell (E210882) Motherboard
Ethernet Controller
Hi
E210882 is a number found on more than one Dell System Board. Dimension 8400 and 4600 come to mind. Possibly there are more. Secondly, E210882 is not a Dell Part number (DP/N or DS/N). While Dimension 8400 is a 775 socket, Dimension 4600 is a 478 socket. So they don't fall to the same family.
In any case the network controllers used on Dell System Boards are Intel and Broadcom.
To proceed, at least provide/confirm the system model. If this is not available, give the Dell Part Number.
Mile
Jul 10, 2008 | Dell (E210882) Motherboard
Dell (E210882) Motherboard Logo
562 people viewed this question
Alun Cox
