Question about DameWare Mini RemoteControl
When i connect Windows 7 pc it gives a black screen
  • 1,218 Answers
There are various steps to manually rectify the black screen error such as rebooting the system, cleaning up the registry files and running antivirus program. But these steps might not set the system right and may land the user in trouble if the procedure is not properly followed. The system may also be completely damaged due to corruption of the important files and other settings. Thus, it is highly recommended to seek the help of computer experts.
Posted on Feb 04, 2011
  • Mike Mar 10, 2012
    Most people using Damewware are advanced users for you to suggest they speak to a computer expert is ridiculous and shows what a ******** you are. do us all a favor and stop replying to post for help
  • David Wingo
    David Wingo Aug 03, 2012
    Amen, Dento!
Why do I no longer have sound for my FB videos?
It's difficult to give you a full diagnosis, but here's one thing you can try.
Go into the bottom right of your screen to the task tray, and find your volume icon. Click on this. You will then have the option to expand this dialogue and control the individual volume levels for each application. It's possible that your browser's volume has been reduced to 0%.
I hope this helps or at least gives you a starting point!
Jul 24, 2014 | HEWLETT-PACKARD Hewlett Packard Compaq...
Panasonic tx p50u30b Black/Blank screen
Might be a resolution issue. Make sure the resolution in windows for that monitor is set to 1920x1080.
Mar 13, 2014 | Microsoft Windows 7 Ultimate 64bit 1 PC...
I installed windows 7 on my ( D:) I didn't like it
Hello, That black screen is actually called a 'boot loader' It gives you the options for what you would like your computer to boot in. To remove it, go into the operating system you would like to permanently use, being xp, vista, or win7 and download and install this program. It is called Easy BCD.
http://neosmart.net/download.php?id=1
The program is pretty straight forward to use, you just remove the entry for windows 7 and you are right to go. If you are having trouble, look on youtube for some tutorials. Here is a link to the search i did.
http://www.youtube.com/results?search_query=easy+bcd&aq=f
Hope this helps,
Steven *******
Aug 08, 2011 | Computers & Internet
The computer won't boot Windows 7. It starts up fine, with the fans running with the LED lights on. Then I get an error message: "CD-ROM Boot Priority ..No Medium" I have checked the bios of...
It sounds like either Windows 7 did not install properly or you have a bad hard drive. I did some research on similar problems and most people have also tried to change the boot priority with no luck. If your are tech savvy I would try to run hard drive diagnostics and possibly reinstall Windows 7. If you are not very technical I would suggest taking it to a competent pc repair technician.
Apr 08, 2011 | Systemax SYX Crossfire X58 Gamer Intel...
I'm trying to change the screen resolution while running windows 7 because I have no desktop showing on my monitor
Firstly, there appears to be many causes of the black screen issue. The symptoms are very distinctive and troublesome. After starting your Windows 7, Vista, XP, NT, W2K, W2K3 or W2K8 PC or server the system appears normal. However, after logging on there is no desktop, task bar, system tray or side bar. Instead you are left with a totally black screen and a single My Computer Explorer window. Even this window might be minimized making it hard to see.
If you have these symptoms you can safely try our free Black Screen Fix. It will fix the most common cause we have seen of this issue. Running the fix program is easy under normal circumstances, simply download with your browser using the link above and run the program. However, if you are trying to do this from the PC which has the black screen it is a bit more tricky. In these circumstances follow the procedure below: 1) Restart your PC 2) Logon and wait for the black screen to appear 3) Make sure your PC should be able to connect to the internet (black screen does not appear to affect this) 4) Press the CTRL, ALT and DEL keys simultaneously 5) When prompted, Click Start Task Manager 6) In Task Manager Click on the Application Tab 7) Next Click New Task 8) Now enter the command: "C:\Program Files\Internet Explorer\iexplore.exe" "http://info.prevx.com/download.asp?GRAB=BLACKSCREENFIX" Note this command assumes that you are using internet explorer as your browser, if not substitute your browser path and file details for those of iexplore.exe or use the Browser option of Task manager to locate it. 9) Click OK and your browser should start up and begin the download process 10) When prompted for the download Click run, the black screen fix program will download and run to automatically fix the issue. 11) Now restart your PC and the black screen problem will hopefully be gone.
Oct 11, 2010 | Computers & Internet
My laptop came on but my screen is black. I can hear my coputer on but my screen is staying black.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen.use registry cleaner reg in out to solve the issue
Sep 13, 2010 | HP Pavilion dv6000z Notebook
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
Computers & Internet Logo
2,121 people viewed this question
Top DameWare Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a DameWare Computer and Internet Expert? Answer questions, earn points and help others
