Lights keep flashing on Epson DX4000
Hi - Recently bought an Epson DX4000. When the printer gets switched on, all LED lights are continuously flashing. We have bought it the ink, checked for foreign objects, completed the steps to add new hardware, got the drivers for the printer, scanner etc. But the lights still continue to flash on and off. Haven't been able to print a test page nor any other kind of page using text on WordPad or MS Office.
Has anyone got any advice for me please.
Many thanks
Brenda
email: davidbeloveddavey@yahoo.co.uk
  • Anonymous May 25, 2008
    I have a red light flashing on my DX4000, there is nothing jammed in there at all, and I can't print a thing!!
  • Anonymous Aug 12, 2008
    I have exactly the same problem.
Joed911
  • 4338 Answers
SOURCE: HP940c Will not print
Here is HP's document on why the light blinks and what the solution is:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09170&lc=en&dlc=en&cc=us&product=59129&rule=26188&lang=en
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 04, 2008
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Posted on Feb 16, 2009
SOURCE: epson stylus 1290 - machine locked up
You can download the repairer's manual for free from http://pcprinter.blogspot.com/2008/05/service-manual-for-epson-89012801290.html  which is where the solution below is listed (p.68).
Basically Epson want you (or, rather, a service centre which you'll have to pay!) to replace the waste ink pad every so many copies. However, you can reset the printer even without replacing anything by switching it off on the silver button, switching it on again whilst holding down the two black buttons alongside it, then releasing them all before quickly holding down just the left-hand black button for 10 seconds. You have only three seconds to do this after switching back on, whilst the green and red lights are flashing together. If you're not quick enough on the first try, switch off using the silver button and repeat the procedure!
Posted on Mar 07, 2009
SOURCE: Red & Green Lights keep flashing on Epson Stylus Photo1280
I had the same problem. You need to reset the waste ink counter:
1. Turn printer off, unplug power cord. Disconnect computor interface cable (back of the printer).
2. After one minute, reattach power cord, but not the computor interface cable.
3 Hold down the LOAD/EJECT and CLEANING buttons simultaneously (cleaning button has ink drop on it) .
4 Turn printer on. Release all buttons as soon as the paper out light flashes.
5 Quickly press the cleaning button, and hold for 10 sec while paper out light flashes.
6 Release the button and the printer will initialize.
7. Once the initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on and try to print your document.
This process worked for me. Good luck!
Posted on Mar 30, 2009
SOURCE: My Epson Stylus DX5000 won't work.
i had the same problem and checked for paper jam but wasnt any so i kept turning on the printer while looking in side and found that one of the little white cogs where the ink box rests wasnt catching when i pushed it into place the printer set itself and started working maybe you could try this. good luck.
Posted on Apr 16, 2009
Lost my disk for the epson dx4000 sytus printer and want to put it to my laptop
Hi Daz,
Please go through this link http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX4000-printer/Drivers-Support and download the driver for your particular printer and install.
Regards,
Shibi
Jul 19, 2011 | Office Equipment & Supplies
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
Epson Stylus DX4000 printer not working
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX4000-printer/Drivers-Support?supportLandingPage=true
Mar 20, 2010 | Epson Office Equipment & Supplies
Epson Stylus C62 Error Red light wont go off
Hi victorarcas
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced (see later). You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C62 Service Manual". You will often find them for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Please rate this solution if it has helped you
Dec 22, 2008 | Epson Stylus C62 InkJet Printer
Epson Stylus Ink Jet Printer
1. Turn printer off
2. Press the left 2 buttons down and continue holding them down while turning the power button on. (all 3 are now pressed down)
3. In 3 or 4 seconds, the paper feed (jam) LED light begins to flash. (middle button)
4. Within 3 seconds as the paper feed button LED still flashes, release all 3 buttons together and immediately press down the ink cleaning button (left) and continue to hold down for about 10 - 20 seconds. As soon as the cleaning docking button LED flash, release it. That's it! You are now reset and ready to go.
NOTE: This is a strict timimg procedure and must be done fairly precisely in order for it to work. It may require several attempts for it to work for you. But...it does work! Happy printing!
Oct 12, 2007 | Epson Stylus Color 880i InkJet Printer
1,310 people viewed this question
jasbo
jasbo
