Question about Nikon COOLPIX L18 Digital Camera
I have a nikon coolpix l18 i bought more than a year ago. now, it having lens error every now and then and when it is ok, the lens no longer retract when it is in viewing mode. what could be the possible cause of this problem? thank you.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Jul 28, 2012
SOURCE: lens error message on nikon
You have to push the lens back in.
Posted on Nov 07, 2008
robmcd27
  • 423 Answers
SOURCE: Nikon Coolpix L18 Driver
Try this, it may work without the software.  Turn off the camera. Plug the usb cable between the camera and the computer. Turn on the camera. If a box pops up on the computer asking what you want to do, scroll down and see if there is an option to view pictures. If a window opens up with all your pictures on it, great. Now open up a folder where you want to put your pictures. Bring up the other window with the pictures in it and hit the control key and the d key at the same time on your keyboard. Then drag your pictures to the window where you want them and let go of the mouse key.  They should all move over. Then you can use Windows image viewer to see them. Let me know if that works.
Posted on Feb 18, 2009
welcomejee
  • 10594 Answers
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
Posted on May 01, 2009
localwonder
  • 6784 Answers
SOURCE: washed camera and lens goes out but screen says lens error
OK, this is lens mechanism failuer due to water damage. the core micro board will start to malfunction in time. this repair will need to be initiated by a Nikon tech. you will need to contact the manufacture for a repair ticket and the nearest location of a repair terminal as well. the actual lens mechanism you will need is not available to the public and, the board as well.
Posted on May 27, 2009
  • 11967 Answers
SOURCE: how to solve NIKON coolpix L18 lens error? The
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 13, 2010
My camera gets "stuck" and
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Aug 23, 2011 | Nikon COOLPIX L18 Digital Camera
Lens error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 31, 2010 | Nikon COOLPIX L18 Digital Camera
Nikon COOLPIX L18 Digital says lens error!
Sometimes the lens is just stuck, sometimes it needs to be replaced. Try to mechanically move the lens in and out by gently twisting, pushing and pulling. If that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Apr 19, 2010 | Nikon COOLPIX L18 Digital Camera
CoolPix L 18 Problem
It probably can be fixed if you can get to them. Most cameras' lens assemblies are replaced as a unit when they go bad, it's just not cost effective to spend the time to tediously take them apart, repair the problem, and reassemble. You sound pretty mechanically inclined to have fixed the gears, so I would say you could probably pull this off if you try. Good luck, it's not what most people should try at home!
Mar 26, 2010 | Nikon COOLPIX L18 Digital Camera
Lens Error on L18
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 23, 2009 | Nikon COOLPIX L18 Digital Camera
Washed camera and lens goes out but screen says lens error
May 27, 2009 | Nikon COOLPIX L18 Digital Camera
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Lens Error on NIkon CoolPix L2
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 31, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
47 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
