Question about Thermador HDDW36FS Kitchen Hood
Is there a direct feed needed or can you have a box conection
  • 8,197 Answers
The vent hood can use a direct feed or you can use a box conection. You can get the install manual on the link below And on page 5 tells you how to wire.
http://www.bshextranet.com/files/techtoolbox/HDDW36FS_IM.pdf
Good Luck
Posted on Aug 07, 2010
Replacing all relays under backseat of 2000 mercedes S500
Open the hood locate the fuse box on the passengers side near fire wall back feed 12 volts into to large fuse that is loose all by its self conected by 2 wires .I think its a 40 amp . By back feeding 12 volts into the system you can pop the trunk lid with the door switch.
Mar 08, 2012 | 2000 Mercedes-Benz S-Class
Wiring for socket for attaching to end of wire
It can get confusing. I am an electrician, and I usually go to a working phone jack to see what colors the last guy used, or open the box on the outside of the house. The 2 phone circuits are red-green, and black-yellow in the jack, but the wire feeds could be any color.
Dec 16, 2011 | Office Equipment & Supplies
My (Cable Service) wire feed is directly behind my HDTV and hooked up over my fireplace . The Rxv667 is located on a side wall book shelf. I have A HDMI wire running to the TV from my receiver. Do I need...
Is there a set top cable box, or are you feeding the cable directly to your HDTV (coax directly to the TV). If you are feeding cable directly to the HDTV then you don't need HDMI. There maybe exceptions, but most TV's don't have HDMI output. The only thing you need to run from your TV to the Yamaha is an audio cable. I assume your HDTV has an optical audio out (either TOS or coax.... Your Yamaha will accept either). Connect the optical audio cable to the AV4 input on the Yamaha. This way when you hit the TV scene button on the Yamaha remote, it will select the AV4 audio input (the default for the TV scene). The optical cable will feed the full audio signal, so that the Yamaha can pass through the surround sound or use the decoder as appropriate to feed your 7.1 or 5.1 speaker system.
If you have a set top box, you may be better off moving that near the Yamaha. In this case, cable goes to settop box, output of set top box via HDMI or component video (RGB) and optical audio to the Yamaha (if you use HDMI Input 2, and AV4 for the optical audio (if necessary), the TV Scene will select the appropriate inputs) and then an HDMI to your HDTV.
In case one, you may need to setup the TV to process the audio appropriately. I have experience with Panasonic Plasma but thats about it.
Feb 24, 2011 | Yamaha RXV667 Receiver
HELLOOOOOO HOW CAN CONECT MY SUBWOOFER
Your problem is quite simple. The low input is for feeding a lead straight from the output of your receiver IE sub out and the high input is for connecting the sub directly to your speaker output where the alternative is not possible. Hope this helps
Jul 15, 2009 | Wave Audio CS801 Speaker
Not DTV ready?
it meens the tv set is in dtv and the dtv conection is not set up.
hd tv is a red blue a green cable.
and the antena conection needs to come from a converter box if signal is coming from antena if from sat or cable you should have a hd box that feeds your set.
hope this helps.
daniel.
Jan 13, 2009 | Panasonic CT-27SC13 27" TV
Conecting DVD/VCP to tv through DIRECT SAT. BOX
You will need what is called an RF modulator. What this device does is to take the place of the internal mod that Used to be included on old VCR/DVDs....accordianman
Feb 26, 2008 | Televison & Video
The picture has a double image.
All conections to the set need to be check very carefully starting form the cable to comes into the cable box from the outside and the cable that goes from the box to the tv,eliminate the cable box and conect the wire from outside direct in the tv and and see how it looks bring a small portable and conect the cable to it to see how it looks,once all the possibilities have eliminated then consider a problem inside the tv in the tuner area starting at the very conector where the cable conects.All this can help if the double image is not related to misaligned convergence.
Oct 01, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Thermador HDDW36FS Kitchen Hood Logo
909 people viewed this question
Top Thermador Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
