Question about GE Profile JTP56 Electric Double Oven
How do I remove the control panel on a built-in GE profile oven
    Guru:
  • 310 Answers
4 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Posted on Mar 28, 2009
SOURCE: Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Posted on Jun 18, 2009
KevinWhite
  • 1902 Answers
SOURCE: !0 year old GE Profile
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Sorry for the bad news....but hope you understand. Please get back to me if you have any other questions.
Kevin
Posted on Jan 03, 2011
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Built in double oven GE profile
    F7 code is 'shorted matrix or start key' could be due to a problem with the key panel or control.
    Aug 05, 2008 | GE Profile JTP56 Electric Double Oven
    How to remove the touchpad on ge profile stove, I have f7 code
    On most GE ovens you open the door and across the bottom of the control panel there are 3 1/4 inch screws, one in the center and 2 on either end going straight up into the console. remove the screws and slide the control panel up then out to you. Thats how you do it.
    Aug 28, 2011 | GE Profile JTP18 Electric Single Oven
    Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
    F7 stuck keypad
    Stuck keypad may mean relay is turned on.
    Determine if problem is with the Key Panel or Control by:
    1. Pushing CLEAR/OFF pad.
    2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
    If code recurs, problem is in the control. Replace control.
    If code does not recur, problem is with the Key Panel.
    Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
    I have a GE Profile built in oven and the F7 display with the beeping sound. Clear or cancel will not work What do I do
    Well, F7 error code occures due to
    A = Function pad button stuck or
    B = Bad clock Unstick button or
    Replace Electronic Range Control (ERC)
    Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
    REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
    Good Luck!!
    Jun 28, 2009 | GE JGRP17 Gas Single Oven
    Jun 18, 2009 | GE Profile JT912 Electric Single Oven
    F7 error
    Good Luck!!
    Have a nice Day!!
    May 03, 2009 | GE Profile JTP18 Electric Single Oven
    Try this link
    Mar 28, 2009 | GE Profile JT952 Electric Double Oven
    My GE profile oven is giving me a code f7 and I can't clear it.  What does this mean?
    Best of luck!!
    Thanks
    Dec 02, 2008 | GE Profile JTP56 Electric Double Oven
    GE Profile JTP56 Electric Double Oven Logo
    407 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Oloyede Monsuru
    Are you a GE Oven Expert? Answer questions, earn points and help others
