Question about Garden
Just looking for the gas to 2cycle engine oil ratio
  • 43,501 Answers
Most manufactueres are running 40 or 50 to 1... to find out exactly what you need we need to know what make engine you are running...many like Stihl have the oil already prepackeg in bottles for mixing to 1 gallon of gas...
heatman101
Posted on Aug 07, 2010
I have a B&S weed trimmer Model 21032. I wish to put in some gas stabilizer but I don't know the fuel tank capacity. Any idea?
The easiest way is to mix it in your gas can as you buy gas at the service station.
If it's a 2cycle, most of the oil mix I buy says on it that stabilizer is included in the oil mix. Fuel stabilizer does not take the place of your 2cycle oil mix. I haven't ever had problems with my 2cycle gas going bad even when left for awhile.
If it's a 4cycle you can mix the stabilizer in when you buy gas.
For now, guess at the fuel tank size ( a quart ? ) and work out the ratio to add to the trimmer tank. A teaspoon maybe. A little too much won't kill anything.
Sep 27, 2017 | Garden
Gas to oil mixture
Gas to oil ratio is a function of the oil you are using. Mix according to what the oil says not what the manufacturer of the engine says. Those ratios could/may be the same. IF you mix 16:1 oil (do they even sell that anymore ?) at a 50:1 ratio it will destroy the engine. There will be no problems at 16:1 as the oil recommends.
I have used 100:1 Optimoil (?) when I can find it instead of the recommended 48:1 of my 2cycle. No problems.
Mix the oil in ratio the oil manufacturer says to mix.
Sep 07, 2017 | Garden
What is the proper gas to oil ratio for Poulan Gas trimmers?
most 2 cycle engines it's 2 to 1 mixture i usually just purchase a 1 gallon can to mix mine in and one bottle of 2cycle oil to a gallon is usually exactly what works
Jun 25, 2014 | Poulan Poulan 115 Throttle Cable Assembly...
Chain gas saw
If you are looking for the gas/oil ratio, McCulloch recommends 50/1 gas/2cycle oil mixture.
Oct 05, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
Unit not starting
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
Dec 06, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
My weedWacker don't star I change the spark nothingh happen
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Aug 19, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
What is the fuel mixture ratio?
this will run on 50-1 mix,,but i would run it on a 40 - 1 mix unless yuou use the right 2 stroke engine oil,,if you use car engine oil mix it at 40 - 1 look at it this way,,,its a 2 stroke so it needs oil or it will seize up and reck your engine,,if you put a little more oil in it will smoke a little bit more but it will never seize up,,,mine is 20 years old now,,,time speeks dont it?
Dec 02, 2010 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
Need to know the gas:oil ratio for weedeater FL1500
100 ml of 2cycle oil to 4000 ml of fuel..Which is 40/1 ratio
100 ml of 2cycle oil to 5000 ml of fuel.. which is 50/1 ratio
4 o/z is 118.29411875006815 ml to 1 gallon of fuel (3.79 litres or 3790 ml) Which means 32/1 ratio...I find that to confusing,so it is easier to say 100 ml of oil to 3200 ml of fuel ===32/1.
Oct 27, 2009 | Poulan Featherlite Gas Blower, with Low...
Ryobi gas blower model #ry08570 need gas and oil mix
try 40 to 1 ratio it should say on the blower if not check the ratio on the bottle of 2cycle oil it will tell you how much oil to add to a gallon of gas
Jan 09, 2009 | Poulan Weed Eater Electric Blower/Vacuum...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
