Question about Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch SHE46C06UC/33 and get down to 1 mins left and then goes back to 55 mins or so.. It takes 3-5 hrs for a complete cycle,, any idea's.. thanks,
    New Friend:
I have the same problem. I made a video here. What's a good place to buy a replacement? http://youtu.be/IjYomVSI3hI
Posted on Nov 30, 2013
Its, the control panel! The panel is sending a signal to the heating eletment and it is not reading it back.
Posted on Mar 09, 2011
How long is complete drive cycle for a 98 chevy blazer s-10 4.3
what do you mean by complete drive cycle as it is unknown terminology
Nov 18, 2017 | Cars & Trucks
I have a Bosch Exxcel front loading washer dryer and can't remove the detergent drawer to clean it, plus all washing cycles take well in excess of 2 1/2 hours to complete. Annoying
Normal wash loads do not take over one hour, but you have to set them on clean any stain option and it will take 107 minutes to wash.
It sounds to me like your washer needs servicing by a trained Bosch serviceman, because it should not do this.
Jun 26, 2017 | Bosch Washing Machines
I have a Bosch SHX46A05UC/33 5-cycle dishwasher whose labels on the cycle buttons have also worn away. While the Macmarkus post was helpful b/c I have some of the same buttons, can you tell me the labels...
Some SHX46A washers have 4 cycles and others have 5 cycles.
I'm fairly sure your model has the hidden buttons on the top of the door and you stated you have five-cycle buttons, in which case they will be as follows.
1. Top Rack only cycle or Sanitize
2. Power Scrub Plus
3. Regular Wash
4. Delicate Wash
5. Rinse and Hold.
These buttons are also used for cancelling a wash cycle. Hold down "Power Scrub Plus" and "Delicate" at the same time to cancel a cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration (from left to right) will be:
1. Power Scrub Plus
2. Regular Wash
3. Delicate Wash
4. Rinse and Hold.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Nov 21, 2010 | Bosch 24 in. SHX46A05UC Built-In...
Bosch dishwasher leaving food stains
You may be experiencing this problem due to the soap you use or too much soap. Run a cycle without soap but put a cup of white vinegar in the machine. Then just use Cascade dishwashing packets. If your filters are clean and the pump is working that should take care of your problem. Do NOT use the inexpensive soaps on the market and especially don't use more than what is recommended. This leaves a film on your dishes and will cause it not to clean or rinse well. (I don't have any connection to Cascade - I just know it works very well. Costco brand packets also work well.)
May 19, 2017 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The timer on my dishwasher is really off. No
the best thing to do is replace it ... but make sure all the connectors are in place
Nov 14, 2009 | Bosch Dishwashers
Bosch Nexxt 300 washer takes hours to do a single load
We had similliar problem. We were overloading the wash barrel and using too much soap. The soap was foaming causeing the washer to add rinse cycles hinse more time to the cycle. Make sure your soap has the HE ( high efficiency ) label on it. Hope this helps.
Jun 27, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch dishwasher stuck on '1'/restarts & sanitize not lighting
it possibly could be a bad soldier joint on the heater relay of the circuit board. but if it is then let an authorized bsh tech replace the board since that is a 5 year warrenty part usually. it also could be problem with the NTC-HEAT ASSY- OR FLOW CONTROL. which are all part of the heat assemby.
but the first thing i would check since the time is jumping around on that model would be to make sure that the polarity on the power cord isnt reversed where its hooked up to the d/w
May 27, 2009 | Bosch Dishwashers
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Bosch 24 in. SHU43 Built-in Dishwasher Logo
662 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
