Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Refrigerator hums but it stops when you open the door
  • Waterfall S Sep 18, 2008
    I have the same problem, held the button down, light went off, heard the hum, but how can you tell if the fan is running or not?
  • 828 Answers
Depress the door switch for the fan and light and the light should go out and the fan motor should run. If the fan motor does not run but only hums it may need to be replaced.
Posted on May 31, 2008
The fan is making a humming sound
when door open Temp inside goes up, when close door it tries ti bring temp inside back to where it needs it also it will generally only try to work when in closed environment don't sound like any "Fault" tho
Aug 22, 2015 | Samsung RF265AB (258 cu ft) Bottom Freezer...
Kenmore elite refrigerator
Check the door switch by depressing it with your finger. maybe not making contact that well with the door ?
Dec 12, 2013 | Refrigerators
My LG refrigerator model # LFX25960ST/bottom freezer, is making a humming noise that stops when we open the door. What is it?
my refrigerator before making a loud noise when we open the door. i called mr.apliance he replace the evaporator fan.......
Sep 25, 2010 | LG Refrigerators
Both the refrigerator and freezer are set to the recommended temperature, however, the refrig unit is making a loud humming sound. This sound stops when you open the door, but begins again when it is...
There is a fan that blows cold air into the refrigerator. It usually stops when the door is opened. Check to see if it might be frozen with ice if the humming sounds abnormally loud. Usually if it freezes up you cannot hear the fan running and the refrigerator will not get cold enough.
Aug 25, 2009 | Refrigerators
Refrigerator side only cooling to 55 degrees. turned off frig for 7 hours after removing all food and leaving doors open for any ice build up to melt.
do you ;here or feel the freezer fan working and or humming if when you open the door fan stops hold the door light switch by hand to do the same or do you hear a hum and click from behing and rear of the frig if so compressor having trouble starting
Aug 22, 2009 | Whirlpool Refrigerators
Humming sound? motor or fan constantly running
Hi, It is the evaporator fan motor you are hearing. The motor is the only thing that shuts off when the door is open. The fan motor is located behond the rear panel inside the freezer sections.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | LG LSC26905TT Side by Side Refrigerator
Samsung Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Oct 30, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
346 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
