Question about Video Game Consoles & Games
I am looking for the little rubber connector for the analogue joystick on a psp do you know where i can obtain one from please .
    President:
  • 1,944 Answers
The analogue joystick isnt working properly. the character wanders off in wrong direction on its own.
simple, get a replacement joystick module and install it on your psp. i did a couple. the psp really isnt that intimidating to take apart. compared to an xbox 360 or playstation
Dec 01, 2010 | Sony PlayStation Portable (PSP) Slim...
Anyone replaced the Slim analog before?
You are risking to damage your psp using the wrong part, if you want to proceed in this way cut the rubber with a cutter. My main suggestion is buying right controller for your psp.
May 18, 2008 | Sony PlayStation Portable (PSP) Console
Tip
How to Replace Analog Joystick on PSP-2001
If your PSP's joystick won't go in a certain direction -- or characters walk by themselves, this part needs to be replaced. It is sold at the website all the way at the bottom for $16.95 and they can do this repair job for $18 more! However, it's not very difficult. Here are the steps:
Step 1. Open PSP. There are 2 screws on the top of the PSP.
Step 2. There are 4 screws behind the PSP and one on the bottom, as circled in the picture.
Step 3. Remove the faceplate and locate the PSP 2001 Analog Assembly. It is held into the console by 1 black screw, as circled in the picture.
Step 4. Remove the black screw and pry the joystick out of the PSP as shown below.
Step 5. It is important that you remove this clear silicon piece from the old joystick and install it into the new one. Its purpose is to communicate the movement of the joystick from the assembly to the motherboard. It sits between the assembly and the motherboard.
Step 6. After you transfer the piece, pry the motherboard slightly up as you slide the new assembly back in place as pictured.
Step 7. You will need to pry this piece up to slide the assembly into place so that it is seated. Replace the black screw and close it back up.
RELATED ITEMS
PSP-2001 Analog Joystick Assembly
Precision Screwdriver Set
to open PSP, PS2
PSP PSP-2001 Motherboard Silicon/Rubber
on Apr 14, 2010 | Sony PlayStation Portable (PSP) Slim...
After starting a game, not able to control the game. Forward joystick doesn't respond and game gets stuck? It is happening with all the games.
It is more than likely a problem with the Analog Joystick Assembly. This is a pretty common part to wear out in the PSPs, especially the earlier models. The following website sells them joystick assemblies for $14.95 for the 1001 PSP and a little more for the newer models. You can find the model number of your PSP on a label inside the back of the PSP if you remove the battery.
http://store.richspsxparts.com/pspanstasre.html
Oct 24, 2009 | Sony PlayStation Portable (PSP) Console
My joystick is not working normally as it use to be.
I know how to solve this so worry not! here's the solution:
1:your joystick may have a little part that is dismembered so buy a new one
2:ask for a assistant to open your psp to put the joystick properly
3:I have the same problem so here's what I do.
good luck
Jul 24, 2009 | Sony PlayStation Portable (PSP) Console
PSP joystick won´t work
It should work fine without it. Make sure you keep that little clear rubber part safe. It's what fills the gap between the analog stick and the motherboard on the PSP
Jun 16, 2009 | Sony PSP (Piano Black)
Psp moving by it's self still.
If you take the front cover off your psp then the joystick/analogue stick is attached onto it. This can easily be taken apart for cleaning. If once you have done this it is still moving by itself then check the rubber connector that connects the joystick to the psp (in metal bit under joystick) this may be dirty, if so then clean this. If everything seems clean and it still moves by itself then replace the joystick (can be bought from www.consoleparts4u.co.uk) this is an easy task once you have got the front of your psp off.
Hope this helps
Mowcius
May 12, 2008 | Sony PlayStation Portable (PSP) Console
Psp moving by itself
Hey, looks like your PSP may have one of these two problems. There are 2 screws on the backside of the PSP System on the side of the analog stick. If either of the screw is loose then the analog stick will move by itself.
Second problem is the Analog Stick itself has been damaged. You can replace these very easily if you are good with tools and electronics.
Bimmerhp
Jan 22, 2008 | Sony PlayStation Portable (PSP) Console
Psp joystick problems
Good day all
I recently ran into this same problem of a PSP joystick "jumping" or hopping around. Since I'm an electronics engineer I was determined to get to the bottom of this annoying problem, I read all the posts on the site and none helped, but the problem turned out to be much easier fixed than I first anticipated.
First of all I assume that you know how to take the PSP apart and take out the joystick module as well. The Joystick module connects to the PSP mainboard by means of 4 contacts, seperated by a spacer conductor that appears like a rectangular rubber, be careful not to lose this during the process.
Here is why the problem occurs, when you have a faulty joystick module, one or more of those 4 contacts don't connect to the main board anymore, so the when the PSP is trying to measure the resistance to determine the joystick position, it reads a varying value, i.e. the contact is floating.
This happens for mainly 2 reasons, dirt or a faulty module, as stated in the previous posts, the contacts could be dirty, but this can usually easy be seen, and this wasn't the problem in my case, I had a faulty module, but luckily all is not lost.
Here's how to fix a faulty module in most cases. Remove the joystick module from the PSP completely, put that little rectangular rubber on the 4 contacts (clear in my case) aside and keep it safe. There is metal clasp on the bottom of the module, you can simply pop it off with a screwdriver, by slightly bending the clasps on the side and taking it off. Now you should be able to see a VERY SIMPLE mini circuit board with tracks on, on the bottom of the module, you can indeed pop this off too. On this you will see tracks where the joystick sliders move. Put the circuit board aside too. Now look at the now completely open joystick module, you will see the two sliders each having a metal part, each of these metal parts has 2 very small contacts that run on the circuit board tracks that you just removed, most times these small contacts get bent inward and they can't make contact with the circuit board tracks anymore. Just bend them slightly outward again, so that when you put circuit board back, they touch the tracks on the board nicely. Put the circuit board back, it just slips back on, put the metal clasp back, put the rubber back in over 4 contacts on the module and voila, if all goes well you will have a nice working joystick module again. Put it back in the PSP and test it to see if it worked. In my case it worked 100% and saved me a few bucks. Hope this helps everyone. Let me know if it worked.
Oct 16, 2007 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
42 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
