Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Frigidaire washer GLTF2940FS1 Error code E20. Apparently a clog somewhere. Can I get it from the front? How? Or do I have to get a strong person to remove it from the closet? How do I unclog?
    President:
  • 1,382 Answers
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you !!
Posted on Aug 07, 2010
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
My frigidaire front laod washer has an E20 error message.
E20 error is known for pump out issue.The first thing I recommend is to take off the front bottom cover(below the door) tilt the washer back some,remove the clamps and hoses from the drain pump.It should be on your right hand side.Check the pump and hose to remove the clogging.This tends to be a common problem with Frigidaire front loaders.Now when you all done with that put it back together and do a test run.
Apr 11, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer will not spin and posts E20 error
E20 means that there is a clog somewhere in the drain line. Check the hose, check the check valve at the pump, make sure nothing is clogged or stuck. It should not take you that long to find the problem.
Aug 23, 2009 | Frigidaire Affinity ATF7000ES Front Load...
My frigidaire front loader washer will not fully drain water and leave clothes soak and display an E20 code
An e20 error is a slow drain. Basically you have a clogged pump. I just had to unclog one today! Unfortunately they are a little hard to get at. Usually they have a small sock or coin stuck in them. The pump is located in the right back. Good news, no cost to fix, bad it's just going to take some time.
Jul 07, 2009 | Frigidaire ATF6000ES Front Load Washer
E20 Error
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Jun 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error codes
I suggest you snake out the drain into which the machine waste hose goes, the standpipe that is. The drain could be blocked somewhere causing pressure problems which is conveyed to the machine. Be sure to replace the machine exit hose at about 3 feet from ground level, and dont shove it too much into the standpipe. Do not block up the point where the machine hose goes into the standpipe, it shouldn't be air tight.
Dec 28, 2007 | Frigidaire FTF530FS Front Load Washer
E20 Error code
It could be a defective or plugged pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in the pipes connected to it. Goog luck!
Aug 26, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
860 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
