AKAI Wide Screen LCD TV/DVD Player Combo.#LCT3201AD
Will not turn on. It started with 19 to 20 attempts, now it will not fire all.
  • pking10288 Aug 31, 2008
    My Akai lct3201ad will not turn on, the problem occured yesterday 8/30/08 but would turn on. Today nothing...... Can You Help?
  • vivkul1 Nov 10, 2008
    Same issue. Red light is on, bur TV does not power on - does not change to green light.
  • 3 Answers
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Posted on Jan 11, 2009
Cant use a dvd in my akai tv combi also it states NOT to use DVDs that are 8 cm what size can I use please
DVD's (CD red book standard) are 120mm (12cm) in diameter the smaller 8cm disc's are the 1.4gb versions. not all "slot" loading mechanisms can accept these smaller type of discs. if you are trying to insert 120mm discs then there is a fault with the mech!
Mar 10, 2014 | Akai LCT3201AD 32 in. LCD Television
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
My akai tv/dvd combo wont turn on?
Hi Nikki,
is there any standby light that comes on at all??
If there isnt than maybe just a blown fuse. replace fuse with the same rating and try again.
Nov 04, 2011 | Akai LCT3201AD 32 in. LCD Television
Akai 32" wide screen lcd tv/dvd combo LCT3201AD
This may be an instance were the idea was great but the execution wasn't thought out. I've heard of several related problems that may be related. Both the TV and the DVD player tend to produce heat, not in great abundance, but together a sizable amount of heat. The power supply may have been ample for the TV at first but with the addition of the DVD player was not able to handle the extra load. If still under warranty you're all set. If not you might call Akai and see what they might be able to do for you.
Sep 29, 2011 | Akai LCT3201AD 32 in. LCD Television
Akai 32" wide-screen lcd tv/dvd
Tramaine, I would suggest a new PSU. I have used in the past with great success. Here is a link to the part you need on their site. Hope that helps! TeeVeeMan2
Aug 18, 2011 | Akai LCT3201AD 32 in. LCD Television
Need wiring diagram for DVD PLAYER ASSY DL-06LS-M1
i'm trying to hook up a dvd player to my lcd tv.i can play a movie through the tv but i cant record tv on to the dvd player.i only have antenna tv can you please solve this problem for me.
Jan 15, 2010 | Akai LCT3201TD 32 in. LCD Television
Television will not turn on with remote or from the tv itself. The red light is on, so it is getting power and we have tried other plugs, so outlet is not the problem. Akai 32" LCD TV/DVD Player Combo...
there are capacitors on the power supply that will be vented or the top bulged out
those will need to be repalced to correct the problem
1000mfd 16volt caps
Oct 24, 2009 | Akai LCT3201TD 32 in. LCD Television
I also have an AKAI LCT3201AD that keeps turning off.
Bad power supply circuit....
Bad resistors, rectifiers, capacitors, or MOSFET devices. Your tv needs to be serviced, and for this problem it should be to expensive and should be 'sameday return. Its an easy fix.
Jun 12, 2009 | Akai LCT3215/26 32 in. LCD Television
The power supply on your LCD failed and will need to be replace or repair.
Let me know if you need further assistance.
Aug 28, 2008 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
