Question about JVC GR-D90U Camcorder
JVC GR-D90U digital video camera will not power on with Battery or when plugged in directly. Power cable tests out good (11vdc), battery apears to be 0V and won't charge when plugged in. If i put a multimeter across the battery charge terminals it reads 0vdc but not sure if i am testing that correctly.
  • 2 more comments
  • hlum88 Jul 09, 2008
    Yes, I got the same issue with jvc grd90u camcorder no power anywhere
    and the tape is stuck. Checked the web in google and found cnet bulletiboard someone mention the fuse on main board might have blown. There's suppose to be diagrams and how to change the fuse.
    Unfortunately, This is a posting in 05' and posting has been locked.
    Will try this weekend to take apart the unit and see where the fuse might have blown. Once I have solution will post to the board. Also, I will try to call the JVC company support for help tomorrow.
  • MABEXT99 Dec 30, 2008
    TAPE IS STUCK
  • Anonymous Jan 16, 2009
    same problem
  • hlum88 May 11, 2010
    New to the board. Not a solution still look for one.
I have the same problem :(
Any solutions/Comments?
Paul
Posted on Aug 03, 2008
  • officesnow Sep 16, 2008
    I have he same problem. Power will not engage even with the cord plugged in.
I can't figure out how to download video from my JVC GR-D90U Camcorder to my computer through it's usb cable. It is a mini DV camcorder that uses mini video tapes.
From the JVC manual "This camcorder can transfer still images to a PC via USB". There is no mention of video transfer via USB so it seems it is not supported.
Sep 25, 2011 | JVC GR-D90U Camcorder
I need to replace the power adapter for my JVC GR-D90U camcorder. Where can I order a replacement?
From page 5 of the user manual, I see that the part numbers for the power supplies that work with this camera are AP-V11U or AP-V13U.
Searching Google, I find it available from JVC for $36.23
I saw that these power supplies have been selling for less elsewhere on the Internet. Just Google search either model number above to see the best deals.
Dec 24, 2010 | JVC GR-D90U Camcorder
My JVC GRD225 camcorder will not power on or charge even when the mains power cable is plugged in. No life what-so-ever.
Well all i like to say that first of all you can try changing the battery of your camcorder, this is the most common problem of not charging error..........
Good Luck!!
Thanks for using FixYa!!
Jul 27, 2010 | JVC GR-D225 Mini DV Digital Camcorder
I get a new battery and it wont charge the camera works when its plugged into the wall but not on the battery itself
Try by inserting another battery, If problem persist then there is a problem in your battery mechanism get it serviced.....
And if problem solved by another battery, Then your new battery is faulty, get it replaced......
Please rate the answer
May 01, 2010 | JVC GR-D90U Camcorder
How to transfer the recorded mini dv tapes from my GR-D90U to my computer
Connect your cam into your PC either by USB or firewire(DV). Install the application software included. You may edit or burn it right away. There are better editing software available int he market today, like WinDVD Creator or Cyberlink Power Director and many more. By the way, to install driver connect your cam first and follow the prompt. Good Luck
Mar 26, 2010 | JVC GR-D90U Camcorder
Camera will not charge when plugged in.
first have look on your battery may be they are finish maked test by a tech if they ok its probly from your power charge circuit in camera, or the pwr pack...
good luck
Feb 08, 2010 | JVC Cybercam GR-D72 Mini DV Digital...
JVC gr-270 drivers
Found driver on JVC website.
Thanks for the follow-up.
Sep 01, 2008 | JVC GR-D90U Camcorder
Help me please....
try removing the battery and take a clean soft cloth and gently wipe surface.
Jun 21, 2007 | JVC Cybercam GR-D90 Mini DV Digital...
JVC GR-D90U Camcorder Logo
174 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
