Question about Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
How to install the router - Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
  • 4,281 Answers
Onfigure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 07, 2010
Nstallation cd is missing for DIR-600...Hello, If you don't have the installation disc anymore, you can...
open the setup page of the router and change the settings manually.
Like other routers, you can install wireless router without installation CD also,
Read how to setup router without installation CD
Jul 04, 2012 | D-Link DIR-600 Router
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
I dont have the disc for instal the router
You can install your router without Disc also. You just need to open the setup page and change the settings manually. Linksys router setup is very easy.
Nov 26, 2011 | Linksys Wireless-G Broadband Router
I lost my belkin installation cd
You do not need the installation CD to use the router. Check this link to download the user manual and quick install manual. As well you can download an updated firmware for your router along with installation instructions.
Good Luck.
May 06, 2011 | Belkin F5D8236-4 Router
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I have DI-604 in line between Windows Vista computer and cable modem. Works fine. Bought DIR-615 (wireless). Several places instructions say, ""Insert the DIR-615 CD into computer and click Install Router....
Contrary to the many warnings not to install the router before starting the installation with the CD, I got the installation to complete only AFTER I installed the router inline thusly:
1. Power everything off.
2. Remove DI-604.
2. Install and connect 615 router to computer and to modem.
3. Apply power to router and modem.
4. Apply power to computer and wait until Windows loads.
5. Insert 615 installation CD.
6. Follow the directions.
Nov 22, 2009 | D-Link DIR-615 Wireless Router
Can I install my belkin router without setup cd?
you may install the belkin router by following the instructions given below.
1. Connect your modem to the internet port of the router.
2. Connect your router to the computer.
3. now reboot the modem and computer.
4. open the router setup page, and click on detect the internet connection.
5. now follow the instructions to install the belkin router. for more information you may follow the instructions given below.
How To Setup Belkin Router Install Belkin Wireless Router Fixotip
Sep 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cant install a router
If you are installing the router between your ISPs modem and your PC, first you will need a ethernet network adpater that installs in your PC, you will need two crossover ethernet cables, one to install between the modem and the router and one between your network adapter and the router, once the cables are connected, turn everything on, first your ISPs modem, then the router and then the PC, once the PC is up, insert the CD that came with the router and follow its instructions and that should work!
Apr 03, 2009 | Linksys WRT54G2 Wireless Router
Lost installation cd
Connect the computer to the LAN port of the router, connect the modem to the Internet/ WAN port on the router, access the configuration page of the router (Example 192.168.1.1)configure the router as dynamic IP (DHCP) and configure the wireless settings as WPA or WEP encryption.
Mar 15, 2009 | NetGear WGR614 Wireless Router
Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH Logo
132 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
