Question about Elektra Nivola Coffee Maker, Espresso Machine
Nivola Please provide me with the 2 following items that I need to replace on my Elektra Nivola coffe maker - Neon light  - coffee maker filter cup holder
  • Gigile Apr 27, 2008
    no parts for the Elektra Nivola
    no part list for the Nivola
  • 758 Answers
To obtain the parts for your Nivola, please click the links below..just search for the items you are looking for on the list..I hope that helps
http://www.espressoparts.com/
Please rate accordingly
Thank you
Computerrep
Posted on Apr 27, 2008
    Genius:
  • 3,422 Answers
Whatever parts you need you can easily get them from HERE
Goodluck,
Please don't forget to rate the solution
    President:
  • 2,267 Answers
Chick here to get more info where to get the parts for your appliance.
They have a live chat to ansewr questions.
  • 1,183 Answers
Http://www.coffeeparts.com/
You can order the parts online on the above website.
Let me know if this is helpful, or furthur input is needed
Mandeep
I need the user manual
Dear friend: I bought mine in 1996 in Orlando. The user manual was so simple with some b/w pictures.
1.- Heat the water.
2.- Over one cup place the thin filter that match perfect and is the bigger one of two elements supplied.
3.- Over the thin filter place the coffe deposit the one that have small holes at the bottom.
4.- Fill the deposit it with coffe for one cup and fill over with hot water slowly from one cup trying not to overflow.
5.- Wait untill the water flows down and your cup of coffe is ready.
6.- For another cup repeat this procedure.
Is a bit long but you can enjoy a room coffe for two.
Its what my experience was. Excelent when you don't find where to boil a cup of water. Now mine machine burns suddenly the heater and I am trying to find the replacement part, but probably should be and adaptation of it.
Good luck. The manual is not much than what I told. Not much manufacturer info. A pitty for a well designed help machine.
Claudio.
Apr 03, 2013 | Franzus TJ-10 Coffee Maker
Just picked up a new Franzus TJ-10 Coffee Maker at a garage sale, but it has no instructions with it. Can you please tell me just how to operate it. Appreciatively, Vincent
1.- Heat the water.
Claudio.
Aug 07, 2011 | Franzus TJ-10 Coffee Maker
How much coffe grounds do I need to put in for 36 cups of coffee
2 cups of coffee grounds for 36 cups of water.
Your manual is free to download here. Page 4 lists combinations of coffee grounds and water for coffee.
I hope this helps & good luck! Please rate my reply. Thank you..
Mar 24, 2011 | West Bend (58036) 36-Cup Coffee Maker
I put in 12 cups of water but only get 4 cups of coffee. what is wrong
Are you sure 8 cups of water is a lot to LOOSE it has to be somewhere i am used to loosing 1/2 cup in the grounds if i make 8 or more cups i have 2 of these coffe makers one in each house the only times i ever loose more is when the filter isnt properly seated and it flows around it and makes a major mess get your coffee maker into a good light and pour water into the filter(coffee maker off) with the carafe out fill it about 1/2 way no water should leak thru then slip the carafe into place the filter should empty if the water flowed when the carafe was out your filter basket and holder arent seated or the valve on the bottom of the holder is clogged and/or held open
Dec 26, 2010 | Cuisinart DCC-1200 Coffee Maker
No coffe in the cup
Hi
I would say you have a stripped thumb screw. It is in the top left side of the brew unit and holds the filter screen in. If it is stripped there will be water or coffee in the pocket on top left of the brew unit.
Dec 26, 2009 | Gaggia Syncrony Compact Coffee...
Miele Coffee Machine won't dispense from 1 of 2 spouts
the spouts located is on door which carry the coffe to final stage to cup of coffee
thanks
Jun 05, 2009 | Miele CVA4070 Coffee Maker
Past 2 mornings, coffee maker only brewed 10 out of 12 cups.
It's probably time for a good cleaning. Follow the procedure in the manual, or get some commercially available coffee maker cleaner. When the minerals build up enough, the water flow and heating is reduced enough to keep it all from passing through.
Please take a moment to rate this solution if it's what you needed, and thanks for asking here!
Jan 27, 2009 | GE 106591 Coffee Maker
GE 169165 12 cup digital coffe maker
after 60 cycles it goes into the clean function, the clean light comes on..., remove the charcoal filter from the water tank, fill tank with 1/2 water and 1/2 vinegar if you want to clean it, just water if you want to get it out of clean mode..., press clean button/light for 3 seconds and clean button flashes and the cleaning process begins...It takes 60 minutes / 1 hr. to complete, light goes off when complete. reinsert filter in tank .
Oct 26, 2008 | GE 106591 Coffee Maker
COFFEE GROUNDS COME THROUGH THE HOLES IN COFFEE BASKET. WHAT TYPE COFFE SHOULD I USE TO ELIMINATE THIS? IS THEIR A FILTER MADE FOR TJHIS URN
Your coffee is too finely ground for your basket. 2 solutions: buy "regular" ground coffee from now on, OR use filters inside the basket. Many 30 cup or 45 cup maker's baskets are sized so that a normal filter, flattened-out, and a small hole torn in the middle will fit into basket and prevent the grounds from passing through.
Oct 05, 2008 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
Steam
I suggest your thermostat is defect. I had the same problem, ordered a new thermostat changed it - bingo!
Jan 27, 2008 | Elektra Nivola Coffee Maker, Espresso...
Elektra Nivola Coffee Maker, Espresso Machine Logo
132 people viewed this question
Top Elektra Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Elektra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
