Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
POWER UP AND IMMEDIATELY POWERS DOWN PC WORLD SUGGEST THIS IS A BLOWN MOTHERBOARD HOW MUCH IS A FIT MYSELF NEW MOTHERBOARD
    Scholar:
  • 104 Answers
This could be a power supply fault,check the volts on the red,yellow and earth lead(black)THE RED LEAD =5VOLTS
YELLOW LEAD=12VOLTS.WHITE=-5VOLTS
BLUE=-12VOLTS,PURPLE,=+3.3VOLTS
BROWN=+5VOLTS VSB
BLACK=GROUND.
Diconnect the pc mains plug from the computer.
Disconnect the power supply leads from the motherboard,and switch on and check the volts on all leads of all those I mentioned.If these are present when they are not connected to the main board,then the problem is with the motherborad,most likely the bios chip is faulty.This chip kicks starts the PC into coming on.Failing this send the PC back to where you bought it and let them fix it.
IT COULD ALSO BE THE MAIN ON OFF SWITCH AND THE CABLE ITSELF FAILING.CHECK THIS WITH AN OHM METER ON X1 OF THE RESISTANCE SCALE.DISCONNECT THE MAINS PLUG FIRST.
Posted on Aug 07, 2010
Testimonial: "A good idea of which way to go after reading the answer. Thanks"
    Problem Solver:
  • 4 Answers
Take battery and power cord out
blow warm air into vents
put battery in and turn on dont put cord in
wrap in towel leave for 45 minutes
plug into power and done
i was amazed when this worked for my f500
Posted on Sep 30, 2010
    Problem Solver:
Try blowing out the vents on the bottom with a powerful compressor, especially the one on the back and make sure the computer is on a solid table and the rubber pads on the bottom are still attached.
Posted on Sep 09, 2010
My HP a1630n was working fine a few days ago & now it does not even turn on - no fan - no motor, nothing. I tried a different power supply & still nothing. Any clues/suggestions??
Try taking out your battery, and then use your power adapter! I just went through this myself.
Your battery may be drained? If your power adapter doesn't work, than you can purchase a universal one, or use the the other you tried. But your battery needs to be out to test this.
My battery was okay, but power adapter was bad...they go bad out of blue for no reason at all! It's fine to use a different power adapter.
Kind regards!
Sep 13, 2011 | HP Pavilion a1630n PC Desktop
Computer was shut down and power turned off. When i restarted the system the printer and monitor came on but the tower is not getting any power. cords are all plugged in and checked outlet works. seems...
If the outlet is good and the cord is good, you may have indeed blown the fuse in the power supply. That is the only fuse. The fuse in the power supply is usually "hard-wired". Not necessarily, but usually. You would need someone familiar with them to replace it if it is blown.
Some computers have a green LED on the back of the computer near the power cord. Do you have one? Is it on? You can also look to see if the small green LED is on on the motherboard.
If you get no indication of power, the power supply is probably gone. A new on is about $25 and pretty simple to replace.
Hope this helps.
Thanks for using Fixya.
Feb 20, 2011 | HP Pavilion a705w PC Desktop
New build with asus M4A79XTD EVO and AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor. When you hit the power button, the fans start but...
Hello
It almost sounds like a mistake at the pc start switch and reboot switch.
Check that you have your pc start wires from the front start button of the case, in the correct spot on the motherboard.
Also remove the memory sticks and reseat them.
The green light on the motherboard is good it means your getting power from the power supply.
The start and reboot switch wiring can be tricky if one plug is in the wrong spot on the motherboard.
Feb 03, 2011 | ASUS M4A79XTD EVO Motherboard
Had to change p/supply installed new 680w apower reinstalled powered up fine shut down moved to where pc would sit plugged in and nothing pulled apart again checked connects powered up fine shut down and...
you could open up the power supply and look for any fuses that may have blown, the ones ive seen are the glass type and are cheap to replace and easy to find at radio shack just take the blown fuse with you and replace with the exact amps. and make sure that everything is unplugged from the wall and be very cautious around the large cylinders inside the power supply aka "capacitors" they can hold a residual charge and WILL harm you
Jan 13, 2010 | EliteGroup GF7050VT-M Motherboard
I push the Power button--but usually have to go thru many tries before machine turns on. It was suggested to remove the PWR plug from the ASUS motherboard and replace it with the RST plug. First time thru:...
hi , by your description i would say the relay in your power supply is deffective , its not a cost effective repair , so change the power supply
hope this helps
Jan 10, 2010 | Antec CASE |P180B BLACK RT
I have a emachine PC. PowerSupply blew up. changed it still down
try to remove the memory and put it back again make sure put it fit and correctly
May 28, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Stand by
Standby does not turn off the computer. It reduces power consumption but does not turn the CPU off or the power supply. Because the cpu is still on the cooling fan stays on to cool it. If you want it to turn the fan off or be silent I suggest using hibernate or shutting it down completely.
Feb 01, 2009 | E-Machines (308714) Motherboard
Monitor goes into 'Power Saver Mode' on boot up!
You need to upgrade your motherboard BIOS to the latest version (V.5a) to support your DUAL CORE 2.5Ghz processor... that's the problem.
Visit:
http://tw.giga-byte.com/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2779
http://tw.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=2779
Jan 07, 2009 | Corsair Memory Corsair VX 550W Ultra Quiet...
My TV is completely dead, no power (F25645)
I would suggest buying a new power supply from ebay or other places.
Dec 31, 2008 | RCA F25645 25" TV
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
738 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
